Arizona Chapter Join Chapter, Leader:
4.6 into an 85 F150?
Old 09-23-2012, 02:26 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
Hey everyone.
Hope y'all are having a great weekend.
Ok, does anyone know anywhere I can check to find out what it takes to put a late model 4.6 in an older 85 F150? I've been running it through my mind for some time and think I'd like to find out more about whether or not it would be a worthwhile swap.
Thanks again.
Keith
Old 09-25-2012, 05:00 PM
Bill W's Avatar
Bill W
Bill W is offline
A 4.6 into any truck would be way cool! i know Kevin (Kstone's63) did a 4.6 cammer motor in his 63 f100 and it is bad to the bone! i think it would be worth while to do a swap like it. being i have never done anything of the sort... i really can't help.
Old 09-25-2012, 09:36 PM
kstones63's Avatar
kstones63
kstones63 is offline
Make sure that you get the computer and any engine control modules that you need. The Detail Zone makes a wiring harness for the 4.6 conversions. It is pricey but it is a whole lot easier than dissecting the harness yourself. I did my harness myself and probably have 75-100 hours in it. I needed to lengthen wires to move the computer into the bed of my truck and change quite a bit of the harness. If you are up for the challenge, it can be done.
People are swapping these engines into early Fox body Mustangs all the time. Check in over on www.modularfords.com , they have a mod motor conversion section. I got some valuable info from them. They are kind of hard to get info out of but don't ask stupid questions and somebody will reply after a while. It kind of seems like they need to get to know you first. I asked several simple questions at first and responded to some to kind of break the ice first. They have some very knowledgeable people on that sight so it is worth the effort to go there. Their website is really a Mustang website but people do work on a lot of different vehicles.
Sorry for the long winded answer.
Kevin
Old 09-25-2012, 11:03 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
Thanks for the replies.
I've been running this through my mind for a few years now and think I'd like to learn more, and maybe even get started on the swap.
I had figured on an aftermarket harness just because it would make things a lot easier, but building one myself isn't out of the question either. What I don't know is what sensors/power leads are needed and what other inputs to the computer also.
Is there a curtain year range I should be looking for? Is one model better than another? I'm thinking I'd probably want a motor from a Mustang rather than a truck. I don't know that there's much difference but there usually is between the them. And it's a street truck not a work truck.
Now that Uncle Sam's decided I'm retired I've got the time, so why not build what I want. The truck has so much sentimental value it'll probably never get sold anyway.
Old 09-26-2012, 08:14 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
Don't overlook the 4.6 out of Police vehicles. The weak link on them is the transmissions. The guys I know that have them like them but if you run them up to close to there max the trannys won't take it. A mechanic for a County in Nevada told me the answer was to change the shut off to a slower speed & the cops needed to use their radios instead of the throttle.
Craig
outracn
Engine Swaps
08-24-2022 10:33 PM
drtnshtr
1997 - 2003 F150
03-02-2008 01:28 PM
Blue50F-1
Engine Swaps
07-22-2005 10:44 PM
MoRePoWeR
Engine Swaps
12-08-2004 06:31 PM
TryMe
Modular V8 (4.6L, 5.4L)
09-11-2003 01:52 PM
Quick Reply: 4.6 into an 85 F150?
