The gears are always churning
Old 09-23-2012, 01:10 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
So, I have had this idea about the independant front 4x4 like the Aerostar has. And as we are walking around the junkyard I find an Expedition that has been rolled. It runs good and I can get it cheap. The track width is a little wide, 72 inches outside so that is a little of a problem Unless I can redrill the hubs for some earlier wheels with a more favorable offset.
Now I am usually the first one to discourage frame swaps but I still can't help thinking how a fridge body would fit that chassis. It has torsion bars so you can get it pretty low, I like a pickup I can work out of and not have to crawl up in the bed after things.
Old 09-23-2012, 07:27 PM
spurredon's Avatar
spurredon
spurredon is offline
Well, if you stop thinking and dreaming they might as well throw dirt in your face right now! That does sound a little wide. I assume you have considered the crown vic approach?
Old 09-23-2012, 07:53 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Redrill the hubs. Tires are so innaccurate and out of round, it doesn't make that much difference if you are 2 thousands off or whatever. 4 wd, independent suspension.... sounds good. BUTTTTT the crown vic thing if you are of that ilk... lower, etc I think from reading here that it is a match made in heaven. ... Disc brakes (12" I think) bolt on... 34" frame width. Now if they only made a 4wd crown vic............
parkland
1999 to 2016 Super Duty
17
06-11-2012 10:53 PM
49fordpickumup
06-29-2011 01:32 PM
brucelee
07-22-2008 04:49 PM
Nyoonch
1947 and Older Ford Trucks
05-02-2007 11:45 AM
OlBlue38
02-01-2003 01:27 PM
Quick Reply: The gears are always churning
