1996 F250 fuel system
Old 09-21-2012, 06:36 PM
tburns17's Avatar
tburns17
tburns17 is offline
i have a 1996 f250 7.3, im trying to figure out what the junction is that bolts to the fuel filter housing. the fuel pressure regulator is a part of this junction as well as the water in fuel sensor. can anyone help?
Old 09-21-2012, 08:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
Welcome to the forum.
IF I understand your question, those bolts (there are two) are precisely to join the FPR to the fluel filter housing, but if I missunderstood, this is a BUMP for you. But the water in fuel sensor is not part of that, its the fuel restriction sensor IIRC.
Old 09-21-2012, 08:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Old 09-21-2012, 09:01 PM
dosecobanya's Avatar
dosecobanya
dosecobanya is offline
Thanks for that link, I know what I'm doin' tomorrow!
Old 09-21-2012, 09:04 PM
tburns17's Avatar
tburns17
tburns17 is offline
its the junction that those two bolts are holding to the housing, mine is cracked and leaking. it has 2 rubber lines that connect to it and two solid lines to it. plus that sensor. i am trying to figure out what that whole junction that all those things connect to is?
Old 09-24-2012, 10:47 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Thats the FPR (fuel pressure regulator)
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
You are welcome. Good luck.
Old 09-24-2012, 10:55 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
here you are
Torsten.H
09-26-2016 11:57 PM
Stephenn95
04-19-2015 01:01 PM
Nick 99
12-07-2014 04:48 PM
Jim Hunt
08-18-2010 12:32 PM
copperdog
01-28-2009 08:58 AM
Quick Reply: 1996 F250 fuel system
