Prepping 534 for long trip
Old 09-18-2012, 06:13 AM
poates's Avatar
poates
poates is offline
Hi folks -
Newbie here, but grew up with C series trucks in the fire department and just bought one. 1970 C850. 5sp. Very nice shape. Fire body removed. But here's the question:
I need get it from FL to CT. It has 17K miles on it. I think I might drive it, burning the numbers off my credit card for fuel. What should I do to prep it? I don't know exactly where it's been recently and what condition internals are. It looks good and sounds good. I'm thinking things like:
- change all fluids and filters
- proactively change all belts, hoses
- maybe even change out the alternator if I can't tell age
- does this engine have flat tappets? should I make sure I have oil compatible with older engines (zinc/phosphates)
- transmission fluids, filters
And any chance I'd get over 5 MPGs given that it is empty?
Thx for your thoughts....
poates
Old 09-19-2012, 10:43 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Welcome to FTE.
This engine has flat tappets with hydraulic lifters.
Something like Shell Rotella 15w-40 would work methinks.
That zinc thing is mostly for break in afaik, but it isn't a bad idea to watch that with an older engine.
Shell Rotella® Products | Shell Rotella
As far as your prep, sounds good. Not sure I'd change the alternator.
5 mpg is what I'd expect.
Old 09-26-2012, 03:52 PM
manglass's Avatar
manglass
manglass is offline
If it's been sitting a lot you might want to change the thermostat too. Worst case, you can always remove it on the side of the road. If the alternator is charging, it should be fine for the trip.
Lou Manglass
Old 09-26-2012, 08:44 PM
poates's Avatar
poates
poates is offline
update
thanks for the feedback so far. I've held off pulling the trigger. Geez, its a nice truck, and really cheap, but want to make sure I respect what I am getting into.
I've searched the site for parts sources for the 534 cu inch and am not finding much. I also talked to my local NAPA guy and we had trouble finding filters and other parts for it. BUT, I know there are a lot of fire departments out there still running these, so they are getting parts from somewhere. I guess I need to call FordMoCo and check.
Anyone have a reliable parts source? Hard to commit to a long term relationship with a big engine if I can't take care of her
Paul
Old 10-18-2012, 07:18 PM
Rodney R's Avatar
Rodney R
Rodney R is offline
Plugs, points, condensor. Each year, Period. Always meant about 1mpg on our '73 L900. That would take it from 3mpg up to 4 mpg, even if it sounded like it ran fine.
Rodney
dirtboss
04-04-2016 04:24 PM
96_4wdr
Aerostar
13
11-19-2012 12:58 PM
JulesR
13
04-16-2009 08:57 AM
Red Ford Truck
General Automotive Discussion
30
03-31-2009 01:31 AM
87 F-150 I6
11-11-2007 08:41 PM
Quick Reply: Prepping 534 for long trip
