Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
2005-2008 Ford F150 Truck Super Cab Window Regulator Power w/ Motor Front Door Driver Side
Old 09-14-2012, 01:36 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
BUY HERE: 2005 - 2008 Ford F150 Truck Super Cab Window Regulator Power with Motor Front Door Driver Side
This replacement power window regulator with motor is just what you need to get your Ford F150 in good shape again!
This power window regulator with motor features the following specifications:
LH (Driver Side) FRONT DOOR
Replaces dealer part numbers: 4L3Z1823201BA, 4L3Z 1823201 BA, 4L3Z1823201CA, 4L3Z 1823201 CA, 6L3Z1823201BA, 6L3Z 1823201 BA
Power operation
Direct replacement
Includes power window motor already assembled to regulator
Built to strict quality control standards
Fits Super Cab models only
Super Cab has 2 full size doors & 2 half doors
Does not fit Regular & Crew Cabs
Regular Cab has 2 Full Size Doors
Crew cab has 4 Full size doors
This Ford F150 window regulator with motor makes a great replacement and has good cost savings over a dealer unit.
Installation:
This repair is easier than you may think. You'll find our installation tips helpful. In our experience removing and replacing the door panel is the most involved step in the repair. On most vehicles this only requires removing a few screws and push in clips.
You'll get a great feeling of accomplishment after you complete this repair knowing you saved money and you didn't have to give up your car for a day at the repair shop. Your passengers and other drivers will be amazed.
Fit guaranteed
1A Auto will refund you with no hassle, if this Window regulator does not fit the application stated.
You can use your existing hardware and wiring harnesses. This Regulator will install just as your original does. Save time and money.
Quality
2 Year Warranty. Don't worry, if this regulator should fail to provide satisfactory performance you can exchange it.
Be confident this part will work right. Every regulator is tested after assembly to make sure the cables and all mechanisms are working correctly.
It is important that your new regulator works for a long period of time. The design of this regulator is tested to withstand 10,000 cycles. That is enough to raise and lower your window 3 times per day for 9 years.
Nothing is more frustrating than taking your car apart and finding the part you purchased does not fit. You want the part to fit. This design is test fit on an actual door. When you install it you will have no issues.
Value
Windows that don't work can be frustrating. They can also hurt your vehicles value. An inoperable window could mean $200-$500 discounted off a dealer trade value or asking price.
Some shops and dealers charge more for parts and repairs when they think you don't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly repair bill.
1Aauto
01-28-2014 09:51 AM
1Aauto
02-05-2013 03:37 PM
Quick Reply: 2005-2008 Ford F150 Truck Super Cab Window Regulator Power w/ Motor Front Door Driver Side
