Traction control / Tire size
Old 09-11-2012, 01:43 PM
evilwunn's Avatar
evilwunn
evilwunn is offline
Once in a while when I take a corner my traction control activates and the light will come on. The tires aren't slipping, and it usually happens the first time I drive it for the day, then it won't happen again for weeks. The dealer checked it out this morning and said that because I have 275/65/18's on it instead of the 255/70/18's it came with, the traction control is getting a false signal and activating. He said that they tried to adjust the tire size with their computer but couldn't go to the size I have. He suggested that maybe adjusting the air pressure down a little in the tires might help.
Does anyone know if someone makes a programmer that will allow me to adjust for the tires I have? Has anyone else had this problem?
Thanks for any help.
Old 09-11-2012, 03:50 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
I believe both the Hypertech and Superchips programmers have adjustments to allow for different tire sizes.
Matt
Old 09-12-2012, 06:47 AM
evilwunn's Avatar
evilwunn
evilwunn is offline
Matt
I checked those out online, it says it will recalibrate the speedometer and odometer for the tire size. Do you think doing that might help with the traction control?
Old 09-12-2012, 07:13 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
I would think so. Ford probably has the traction control all figured out based on the stock diameter tire and any deviation from that may mess up the calculations.
Just think if you get the programmer not only can you adjust for the tires but you can pull a few more HP out of it. Win win.
Matt
Old 09-17-2012, 04:04 PM
johnkn's Avatar
johnkn
johnkn is offline
I'd take it to another dealer. There are always varations between manufactures even on the same tire size. BTW, TireRack.com shows Michelin 255x70x18 and 275x65x18 having the exact same 32.1" diameter. Sounds like they had no clue what the real issue is and tried to blame in on the tires.
Old 09-18-2012, 12:43 PM
evilwunn's Avatar
evilwunn
evilwunn is offline
I saw that same thing online, the only difference is with the width of the tire, and the sidewalls are stiffer than the stock tires. I have been to two dealerships already and I am getting the same answer. I did drop the pressure down a few lbs. and so far no issues with the traction control activating. (knock on wood) I guess I'm just going to have to see what happens.
Rob.D
1999 to 2016 Super Duty
07-12-2009 09:25 AM
75 SuperCab
08-28-2006 03:18 AM
STFXGEO
11-21-2005 05:49 PM
InboundFX4
2004 - 2008 F150
09-06-2005 11:34 AM
btnbronc
1978 - 1996 Big Bronco
01-20-2004 05:28 PM
Quick Reply: Traction control / Tire size
