1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fitting size for Brake master cylinder ports?
Old 09-09-2012, 06:06 PM
checksix's Avatar
checksix
checksix is offline
All,
I am installing a 2005 F250 diesel Super Duty brake master cylinder into a 79 crew cab project truck. I need to order the correct fittings for the brake line output ports. They don't appear to be SAE.
Does anyone know the correct fitting size for the front and rear ports?
Thanks,
Checksix
Old 09-14-2012, 07:59 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
Originally Posted by checksix
All,
Thanks,
Checksix
The newer MC most likely has I.S.O. metric (bubble flare) fittings. I can't tell from the photo but probable fittings sizes could be 10mm x 1.00 or 12mm x 1.00.
You could take the MC to the parts store and check it with some of the pre-fabbed lines, with metric bubble flare fittings on them, to figure out which fitting size matches the ports.
Dirty Offio
10-18-2015 07:09 PM
Cougar54
09-29-2014 05:37 PM
ghunt
02-09-2009 12:19 PM
Quick Reply: Fitting size for Brake master cylinder ports?
