Key tumbler fell out
Old 09-07-2012, 12:51 PM
jtindale's Avatar
jtindale
jtindale is offline
Hello,
When I went to pull my key out of the ignition yesterday the key got a bit stuck and when I jiggled it a little to pull it out the chrome bezel that locks the tumbler in fell out. Now the tumbler is out as well and I cant figure out how to get the tumbler in and lock the bezel in place.
I see a pin on the bottom of the ignition cylinder that I should be able to push in and pull the cylinder out but I cant seem to push the pin in at all.
Can anyone help with this? Thanks in advance!
Old 09-08-2012, 03:38 PM
Expypate's Avatar
Expypate
Expypate is offline
The pin will only push in when the ignition is turned to the on position. Reach in and turn the switch on with a screwdriver and you should be o.k. If the pin pushed in while in the locked position it would be way to easy to steal the truck.
I would replace the ign plug if it continues to happen.
Old 09-08-2012, 09:57 PM
jtindale's Avatar
jtindale
jtindale is offline
Thanks Expypate! I did that and went to Ford to get a new cylinder. There was a tab broke off in the cylinder that prevented the chrome bezel from holding the tumbler in place.
Old 09-08-2012, 11:05 PM
Expypate's Avatar
Expypate
Expypate is offline
I'm glad you got it back together. I was a locksmith for years, but now work in the wholesale side of the business. Amazing what you forget when you don't do it everyday.
jtindale
2004 - 2008 F150
09-08-2012 10:01 PM
bozzzz94
Aerostar
07-19-2008 02:20 PM
B-DOGG
1983 - 2012 Ranger & B-Series
03-19-2006 02:10 PM
rhetor
Electrical Systems/Wiring
03-24-2004 09:14 PM
shenders
1997 - 2003 F150
09-09-2001 09:09 AM
Quick Reply: Key tumbler fell out
