Dual Fuel on a '88 F250
Old 09-04-2012, 10:50 PM
GregonVI's Avatar
GregonVI
GregonVI is offline
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->
I just purchased an '88 F250 4X4 351 5spd that has a full propane conversion, for greater flexibility I would like to convert it to dual fuel. The installer used an Autotronic 5910 Dualcurve and I am looking for info from anyone that has expirience with these units.
From what I can see on page 7 of the installation manual:
http://www.dualcurve.com/5910-INST.pdf
all I need to do is wire in a switch and I should be already to go, can anyone confirm or add to this.
I was also thinking that as these unts are no longer available new maybe I should try and find one or two extras in case my dies.
Thanks, Greg
<!-- / message -->
Old 09-06-2012, 12:38 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
If the gasoline injectors, fuel pump and tanks are working go for it, you a 3-way switch that will allow you to switch back and forth. What mixer/system does it have on it?
If it is an Impco CA425 you will need to rig up a solinoid to apply vacumn to the top of the air valve when you are on gasoline or it will run really rich due to restricted airflow.
Old 09-09-2012, 10:40 PM
GregonVI's Avatar
GregonVI
GregonVI is offline
Yes it has a Impco CA425M-2 mixer so that means that I should be good to go . Thanks for your help and I may ask more questions when the install time comes.
Greg
Redneckfordf2502002
11-06-2012 07:22 PM
GregonVI
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-04-2012 10:46 PM
82F100SWB
10-28-2007 08:17 PM
gsx
06-12-2005 04:34 PM
bigbluetruck
11-14-2002 03:05 AM
Quick Reply: Dual Fuel on a '88 F250
