Carb problem ?
Old 08-29-2012, 08:41 AM
chads's Avatar
chads
chads is offline
Carb problem ?
I have a 66 econoline 170ci with a 1100 carb I just rebuilt as the truck was in storage for well over a year. The truck starts fine and idles fine but when I press on the accelerator, it wants to die out. If I keep the choke a little closed and keep the idle up the problem goes away.
I replaced all the vacuum lines and vacuum advance. No change. I also noticed that the clear fuel filter I put on it only has a little fuel in it when running. (Not sure if that is normal)
Any help would be appreciated.
Old 09-11-2012, 01:21 AM
kenjh's Avatar
kenjh
kenjh is offline
have you checked that the accelerator pump is squirting when the throttle is moved ??if the check ball isn't working ..no juice to cover the bog ,,and the choke will give it the rick mix to cover that..and yes some filters never seem to fill but work just fine ..
Old 11-03-2012, 07:35 PM
l8ntpianist22's Avatar
l8ntpianist22
l8ntpianist22 is offline
im new here,but ken is right on the money
Big Daddy T
13
09-30-2009 08:30 PM
59INA40
05-12-2009 09:34 PM
Czarinca
09-18-2007 02:54 PM
littlefoot
02-15-2004 11:14 AM
kevin71100
01-04-2004 11:40 PM
Quick Reply: Carb problem ?
