OK, I tried searching and found nothing. Maybe I suck at searching. Who has new lines for a 1960 3 speed, factory 4x4. I need the line that is part steel and part rubber. It goes between the master cylinder and the slave cylinder.
Ive tried NAPA, Macs, LMC, and Dennis Carpenter. Any thoughts?
Build one? It is brake lines on both ends isn't it? It shouldn't be that tough to come up with a rubber brake line with the right IFF ends to put in the middle.
Did mine willowbilly style. Got the brake hose at napa, but they had to order it. It was about 9" long and female at each end and I bought 2 steel brake lines from the stock on hand. I wish I had saved the part # for the hose.......
I did mine the same way I did my brake master. I used all steel line and put a couple of wraps around a piece of pipe in it to give it it's flex. That's what newer trucks have!
