Trailer Towing
I have a 11' 5.4L Expy with HD Tow packang and a Hensley Arrow hitch. I tow a 34' TT that weighs on average 8700lbs (including my family of 6). Take in consideration, your hitch (sway & weight distribution) properly set up for you truck. Wheel base length plays a key role, but your hitch and driving speed dictate handeling the most. Find out what you truck's gvwr is and stay within those guidelines and you should be ok. With the right equipment and a lot of common sense, it can be done safely.
I tow a 16' trailer loaded with 1 6' Mower deck , 1 6' box blade' 1 6' rotor tiller. 1 Ford 3000 diesel tractor 1 post hole digger; from Katy Texas to Junction TX.
The only problem I had was the 7% grade about 50 miles out from Junction. I dropped to 40 MPH going up it
At the time the truck had over 160,*** miles on it...and yes it was a 4.6
Now that being said it is possible that you have checked all your weights and axle ratings and are within the limits, if so fantastic!
I just say this because I was given the old "yeah you can tow that easy" at the trailer dealership, and expecting them to be the experts I purchased a trailer that was too big for my vehicle after I loaded the family in it.
To the OP
99% of the time you will run out of payload before you reach your maximum towing capacity for any vehicle. I recommend looking at the payload of your expedition (on the tire sticker) subtract the weight of your family if you have kids remember they grow, take a good guess at the weight you think you haul in the car with you (and probably add at least 100 pounds )
My example is this 1650 (payload) - 700 (Family 5+dog) - 300 (junk we pack in the car) this gives me 650 pounds for my hitch weight. your hitch weight should be in the 10-15% of the trailer weight range. I use 13% as an estimator. Based on my family the maximum I can tow is 5000 pounds without exceeding the payload capacity.
Good luck with your towing adventure! I have no doubt that if you stay within your payload and towing capacity you will have no problems at all.
if you dont have a lot of experienced with towing stay within maximum towing capacity for the vehicle
but if your going to do this (not saying its ok) make sure your trailer is loaded right, if not trailer sway and stopping is going to be a problem dont be in a rush and leave plenty of room for stopping
how much weight are you wanting to tow?
MPDano
45
02-10-2016 07:36 AM
jebdrup
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
03-28-2006 11:14 AM
