Cleaning throttle body and intake manifold
I have a '95, 4.9l and pulled off the throttle body and intake manifold as part of the process to change the fuel injectors.
Both the throttle body and the upper intake manifold have carbon in them. I've seen posts suggesting soaking the manifold in mineral spirits to loosen the carbon. But given the size of the thing, it will take a couple gallons in a large bucket to be able to do so. Is there an easy spray available that doesn't harm the original surfaces? Does it matter after 200k miles?
An old tooth brush or bottle brush works great too. The throttle body and intake cleaner works well, but sometimes isn't quite enough. I know most people say not to use carburetor cleaner on these parts, but I've done it many times on several vehicles.
For the intake, I've used engine degreaser and the water hose too. I'd probably do this first, and possibly a second time, before using spray cleaner. You'll get more crud out of it.
J7Bones
1983 - 2012 Ranger & B-Series
15
10-17-2005 07:31 PM
BlueOvalFitter
11-29-2002 03:32 PM
