why not syn?
Old 08-24-2012, 01:39 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
why not syn?
i burn a WMO mix in my rig, and i think i've read that synthetic oil is "bad" to burn in your engine. is this true, and if yes, why, and at what concentration?
most of my used oil supply is dyno, but occasionally i get a gallon or so of syn, and was wondering why its counted as "evil"
Old 08-30-2012, 11:56 AM
Opossum's Avatar
Opossum
Opossum is offline
I'm no expert but I do know 2 things about symthetic oils of note. The general consinsious is it doesn't burn as readily. That for instance if you put symthetic in an engine that burns oil it will "burn" less of it, but likely use more cause it's a smaller molicule and leaks past seals more. That said not all symthetics are actually synthetics. Back in the day it was decided after some court battles that highly refined dino oil can be sold as synthetic. So most lower cost "synthetic oils are what's called class 3 synthetics which are highly refined dino oils with synthetic additives. Finding out which is which can be tricky, not something the manufactures make easy to find out. Amsoil and redline I know are true syntheitcs, I think castrol and mobil 1, and pretty sure royal purple, pennzoil, etc aren't.
Just my $.02
mrf-100
27
02-06-2018 09:50 PM
SweetPete531
3.8 & 4.2L V6
09-23-2015 07:37 PM
lakewood
12-15-2009 01:59 PM
Unimog005
22
08-05-2007 09:04 AM
slave2dafords
12-30-2002 03:25 AM
Quick Reply: why not syn?
