Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
PATS, dead odometer and scanner not connecting
Old 08-18-2012, 09:48 PM
tomshelby's Avatar
tomshelby
tomshelby is offline
I have done alot of searching and reading about the PATS sytem and the blanked odometer.
Ill start with some useful info on my project. I stripped a 2000 lightning and have installed the complete running gear, electronics and wiring into a 56 f100 (pics at shelbycars.blogspot.com ).
The project has been on stand-by for about 4 years until I started working on it again about a month ago. Ive spent the last few weeks installing the harness, electronics etc. Finally friday I installed a battery and turned the key to see what would happen.
first, I noticed the odometer showed "-------". I have read the threads about the blank odometer so I will repair that monday when I get to the shop.
second, the security light was flashing and would not engage the starter. (I do have the coded key and transceiver ring in the system from the donor)
third, I tried for several minutes to connect my innova scanner and it would not link to the vehicle. Finally it linked and I noticed that the odometer was working. Before I was able to pull the codes I lost the connection.
My questions are
1 Does the odometer connection affect the scanner? or just coincidence?
2 Does the odometer connection affect the PATS?
3 Does the key, inst cluster have to be re-programmed due to being disconnected for 4 yrs?
4 Does the transceiver ring have to be programed to the system? I assume it just passes the info to the cluster and woud not need programming
I know that the instrument cluster is a key part of PATS system but not sure about the scanner comm port.
Im not looking for opinions or guesses or "I would think's." Only experienced individuals who have a very good understanding of the systems.
I appologize for my spelling, missing letters and extra letters. Smashed my finger and typing sucks with a huge bandage
Old 08-19-2012, 06:22 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Your symptoms are of a PCM that is not being properly powered. An additional data point would be to observe if the MIL is coming on during initial prove-out.
If the PCM does not receive proper power at start-up, the usual set of observations would be 1) No MIL, 2) Odometer "------", 3) No PATS prove-out, 4) No OBDII connection, and 5) No start.
If this were still in the original vehicle, I'd suggest focusing on the PCM Power Relay.
Old 08-19-2012, 08:32 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
+1 on the PCM relay. Seen it many times. If the cluster cant talk to the PCM then you have those symptoms. Either the PCM isn't getting power or ground, or you have a network concern.
Old 08-19-2012, 09:18 AM
tomshelby's Avatar
tomshelby
Thanks both of you. I am running the complete lightning harness with all relays etc so ill look into the relays, grounds etc. Thanks again
Old 08-19-2012, 12:13 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Sorry Tom, I can't help because I suck at anything electronic/electrical but I had to post up and tell you I think your project is baddass!
Stewart
Old 09-07-2012, 11:16 AM
Poolshark1321's Avatar
Poolshark1321
Poolshark1321 is offline
This is a great idea, thanks for sharing... loving the way that 56 looks man keep up the good work!
cmkabp
1997 - 2003 F150
08-24-2018 07:01 AM
lmarkie
1997 - 2003 F150
03-01-2018 11:16 PM
robertom18
Escape & Escape Hybrid
04-20-2016 10:44 AM
Jay87LX
01-19-2013 06:39 AM
Brian460
1999 to 2016 Super Duty
10-02-2005 07:45 PM
Quick Reply: PATS, dead odometer and scanner not connecting
