16" or 16.5" 5 lug rims
Old 08-07-2002, 05:49 PM
impact's Avatar
impact
impact is offline
Does anyone know where I can find 16' or 16.5" 5 lug rims to fit a ford truck F150? They need to be the 5 on 4.5 bolt pattern.Does anyone even make these rims??
Old 08-07-2002, 06:28 PM
restorit's Avatar
restorit
restorit is offline
[updated:LAST EDITED ON 07-Aug-02 AT 07:30 PM (EST)]They're made, but they're not very popular. I used to have a set on an F150. The last time I checked, Summit Racing carried them (I believe in American Racing or Eagle). I only happened to look at the white spoked "wagon" wheels, which is what I had, but they may also be available in other styles..... (I'm speaking of 16 X 7's..... I'm unsure of the case with 16.5's or wider widths).
Old 08-08-2002, 05:43 AM
Supercab's Avatar
Supercab
Supercab is offline
In any case stay away from the 16.5 rims, as they are hard to find tires for.
Old 08-08-2002, 06:07 AM
rabidranger's Avatar
rabidranger
rabidranger is offline
There are in fact plenty of tires available for the 16.5" rim. I would go with the 16" though due to the nature of the 16.5" rim being more susceptable to losing the tire bead when aired down too low. Like 10 psi or lower... speaking from experience here...
Old 08-08-2002, 09:44 AM
Ford Truck Racer's Avatar
Ford Truck Racer
Ford Truck Racer is offline
Try checking a junkyard for latter model trucks. the 97 later I use 16's and I believe they are the same bolt pattern. You just have to measure it.
Old 08-08-2002, 11:11 AM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
97-up uses the metric bolt pattern and won't interchange with older 5 hole rims.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 08-08-2002, 02:14 PM
honney's Avatar
honney
honney is offline
5 on 4.5 for an F150?? I think you need 5 on 5.5 but you could probably find either as some newer Exploders got 16" wheels.
Just call Tyres Intl or Natl Tire and Wheel
http://www.tyres1.com/
http://www.natltire.com/
They'll have it or can get it.
Old 08-08-2002, 05:30 PM
impact's Avatar
impact
impact is offline
thanks for the info.They do need to be 5 on 5.5 bolt pattern.I need to check my typing a little closer i guess.
Old 09-18-2002, 03:21 PM
oleblueford's Avatar
oleblueford
oleblueford is offline
I was wondering if you had had any luck on this?
I had also heard that the Dodge 5 on 5.5 wheels would work, but had also heard the that the center hole might be too small.
Have any ideas where this could be checked out?
Old 09-18-2002, 04:24 PM
Hit Man X's Avatar
Hit Man X
Hit Man X is online now
Received 1,173 Likes on 954 Posts
mrcman58
Ford Truck Parts for Sale
04-13-2017 03:30 PM
AlbraiNYa
WTB - Parts & other
09-10-2015 07:26 PM
Redneck1465
WTB - Parts & other
17
03-01-2013 05:14 AM
hatchet
Offroad & 4x4
18
11-18-2007 06:32 PM
lt dan
05-25-2001 12:43 PM
Quick Reply: 16" or 16.5" 5 lug rims
