1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2012 F-250 need larger fuel tank
Old 08-16-2012, 06:18 PM
nesport's Avatar
nesport
nesport is offline
I thought I had seen a thread on this, but searching around I keep getting sent to the F-150's, so i'll ask the question.... Is there an aftermarket larger fuel tank available that doesn't mess with the electronics (acg mpg, distance to empty, etc..)? I've contacted Ford and they say theirs isn't available yet. Mine's the 26 galloon, which just isn't enought for towing a large fifth wheel. Only have a range of about 200 miles, which can be problematic out in the forest or trying to fit into a one off gas station somewhere. Thanks.
Old 08-16-2012, 06:41 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Old 08-16-2012, 09:07 PM
biz4two's Avatar
biz4two
biz4two is offline
Thumbs up
Hope this video helps. Done by a FTE member...
<iframe width="640" height="360" src="http://www.youtube.com/embed/-cZggyKhBjg" frameborder="0" allowfullscreen></iframe>
biz
Old 08-16-2012, 09:22 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
Nice
reps sent
Old 08-17-2012, 12:13 PM
majkthreads's Avatar
majkthreads
majkthreads is offline
Transfer flow also makes a metal aftermarket tank which is 50 gal.
Ford pickup replacement tanks
Old 08-17-2012, 12:41 PM
montey2005's Avatar
montey2005
montey2005 is offline
Tell me more about this transfer flow tank?
Old 08-17-2012, 03:27 PM
phantomphixer's Avatar
phantomphixer
phantomphixer is offline
Bizfortwo,
Not trying to be picky but you hold a torque wrench wrong. You must hold a torque wrench by the handle, center of hand, center on handle. You'll get an incorrect torque otherwise. See torqueing at 6 minutes in your video. Just trying to be helpful. Good video on tank change out.
Old 08-17-2012, 03:36 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
....its a bigger fuel tank you bolt under the truck to replace the stock one.
Old 08-17-2012, 04:20 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Originally Posted by phantomphixer
Bizfortwo,
That's not biz in the video, it's user EpicCowlick.
Old 08-17-2012, 04:39 PM
montey2005's Avatar
montey2005
are we talking FORD or Titan tank? I'm guessing the 350's have a 36 gallon right?
Old 08-17-2012, 04:46 PM
2000silverbullet
It's a long bed vs short bed thing for the Ford tank.
Titan is aftermarket.
Old 08-17-2012, 04:47 PM
texastech_diesel
Token Redneck
Titan and Transferflow make aftermarket fuel tanks, Titans are polyethylene (ie plastic) and TF is aluminized steel. Short bed Super Duties come with a 28ish gallon tank, and long bed Super Duties come with a 38ish gallon tank. Expeditions came with a 44 gallon tank between the frame rails.
Old 08-17-2012, 04:49 PM
montey2005's Avatar
montey2005
dam. I have a short bed. I'm sick of this puny tank on a work truck. 1800 miles with a trailer and I'm stopping more often than I need to ****.
Old 08-17-2012, 07:16 PM
AGE mechanic's Avatar
AGE mechanic
AGE mechanic is offline
Short bed diesel trucks come with the 28 gallon tank that holds about 33 gallons.
Old 08-17-2012, 07:55 PM
Irelands child's Avatar
Irelands child
Irelands child is offline
I've done a search for after market GASOLINE tanks and found only one source (forgotten who, but way too expensive at over $1K for only another ~20 gallons) but have considered a bed mounted metal housing/poly insert race car tank with a transfer pump, the line hooked to the filler neck or, if too lazy to pull that filler tube, just stop and stick the hose in the tank fill. I too have a 5th wheeler and I have to say, finding a gas station can be interesting in the boonies - and once there, can I get my 12+ foot high, 35 foot trailer under their @#$% awning. FWIW, my short bed V10 gasser supposedly has a 30 gallon tank according to my owner's manual - and have put 29 in it.
Quick Reply: 2012 F-250 need larger fuel tank
