1965 ford f100 disc brake conversion
Has anyone done this conversion? 100's of member have! There are a gazillion articles inre to this swap here on FTE, but...
You will need more parts than just the spindles, king pins and disc brakes.
1965 kingpins have the spindle pin locking bolt in a different location. You're not using these parts, so don't worry about it.
If you have 65 beams you need to use the 65 Pins. and they are the same diameter. If you use the later pins they are to far one way as dictated by the king bolt bore in the 65 axle end.
65 is the only year that need the specific pin. all others can use later pins.
Will you be having the pins fitted by using bronze bushings or using nylon?
Garbz
Garbz.
Garbz
Garbz.
RenoDa
06-05-2019 01:56 PM
ronix08
20
12-27-2015 10:15 AM
65 Ford Truck Man
08-13-2012 12:44 AM
jloktalGst
18
04-15-2012 11:37 PM
TheRooster12
11-22-2010 07:47 PM
