I have a 96 Ford F150 4 wheel drive pick up. I was told that the speed sensor was bad so I purchased one to replace. I have no idea where it is or how difficult it will be to replace. Can anyone help?
Thanks,
flgal
No problem. The speed sensor/ABS sensor is located in the rear differential just above the drive shaft. It only takes one connector to pull off and one bolt to remove. The bolt on my 94 is a 13mm. It is pretty darn simple. Good Luck and keep us posted.
