gear box id
Old 08-07-2012, 10:03 AM
iggy.ho's Avatar
iggy.ho
iggy.ho is offline
gear box id
Hi, i'm new to this site so please bear with me! i'm installing a 5.0 engine in my 1959 f-100 and wanted to use a manual trans. I bought a good used trans, supposed to be 3-speed with overdrive, not a granny gear 1st. A mid 80s truck trans?? Aluminum case, 4-speed top shifter. # on tag-rts bvh8 e6trma0992 what trans do i have?? Thanks
Old 08-07-2012, 01:42 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Sounds like the top shift version of the 4 speed OD. Other versions are the SROD, where the shifter is back on the left on a turret with a tube connecting it to the main box. And there is an iron cased side shifted version as well. These are patterned after the old Ford "Top loader" performance four speed from the '60s/'70s. They are also called "T170"s.
Aluminum cased versions are the weak sisters of the group. Don't side step the clutch or bang gears....
Domestic Truck Transmission Identification Guide - Rockland Standard Gear, Inc.
Ratios here.
Toploader 4 Speed Transmissions
The site where I found pics is no longer available, but there is a pic of the guts here on the iron cased job:
Toploader Imposters
Old 08-07-2012, 07:44 PM
iggy.ho's Avatar
iggy.ho
iggy.ho is offline
trans info
Thanks for the info, trans should be good for my use. it's my daily beater/ parts chaser.
Old 08-13-2012, 03:58 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I bought a RTS TS-OD 4-speed overdrive trans, aluminum case, 4-speed top shifter. RTS E6TR-MA
What trans do I have?
E6TR-MA = RTS-BV TS-OD (Top Shift 4 Speed Overdrive): 1986/89 F150 302 2WD.
RTS TS-OD = 1984/89 E150/F150 & Bronco.
The multi-part gear shift lever is an abomination foisted on mankind by FoMoCo. The trans is a notorious "weak sister."
One speed shift, you can kiss the little darlin' good bye.
Old 08-13-2012, 08:28 AM
iggy.ho's Avatar
iggy.ho
iggy.ho is offline
gear box
sounds like i should buy a truckload of these trans and keep them handy. the reason i am using this trans, i like the original look of the floorshift, but with the overdrive. Thanks Iggy
fordxxx
15
05-24-2019 09:35 PM
David Hollenshead
01-19-2019 06:04 AM
turbochargedford
08-07-2010 12:19 AM
mailmandon
12-27-2009 01:16 PM
300I6VAN85
05-04-2006 09:50 AM
Quick Reply: gear box id
