1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
can i get prebent brake lines?
Old 08-06-2012, 03:00 PM
mike oconnell's Avatar
mike oconnell
mike oconnell is offline
Smile can i get prebent brake lines?
Does anyone know if i can get pre-bent brake lines and fittings for a 2001 ford ranger xlt 3.0 liter 6 cylinder? I have seen them for other model fords a JBG website
Old 08-06-2012, 05:20 PM
g_k50's Avatar
g_k50
g_k50 is offline
Ford still has those parts available, it might take some searching to find which exact section and fittings you need but check out fordparts.com for pictures and part numbers and prices,
If you're concerned about the price being to high, consider the value of having brakes that work correctly, the value of your truck.
Old 09-02-2012, 09:55 PM
1great40's Avatar
1great40
1great40 is offline
Way too high
I checked out fordparts.com for the hydraulic brake tubing for my 2000 Ranger, a list price of 140 bucks for the piece of tube that runs down the frame is just way to much. I really wanted to just buy the lines and put them in but it looks like I'll be "rollin' my own" again. Making lines from scratch is a pain but I can deal with it
Old 09-02-2012, 11:14 PM
racsan's Avatar
racsan
racsan is offline
heck its just $20 for a 15' roll of steel brake line, yeah, the line nuts start adding up in price, and unions arent cheap either, but once you learn & get good at double-flareing brake line, you can justify the cost of the double-flare tool kit you'll also need. get the "good stuff" yes, its $80 from sears, but the &30 one from autozone just doesnt hold the line good enough when you go to make the flare, i thought it was me being out of practice until i broke down & got a good tool to use then was makeing perfect double-flares every time. you might even find yourself doing work on the side & the tool can litterly pay for itself.
KsHighboy
20
01-10-2018 03:48 PM
big schott
01-25-2014 12:06 PM
Slowdog
10-18-2010 02:13 PM
93 mix 'n match
General Automotive Discussion
03-10-2010 09:52 PM
BarryMc
23
01-13-2009 09:08 PM
Quick Reply: can i get prebent brake lines?
