Retrofitting Camshaft set up questions?
With the rollers, they are less likely to have excessive wear/damage on startup, but that's about it. Roller do have an advantage in they can typically turn higher rpm with less valvetrain mods, you can also run a higher duration as the roller is more relaxed/take a higher duration without affecting idle quality/vacume levels at the low end as much- basically more forgiving (with hydraulic liters)
rusty70f100
10-12-2005 09:59 PM
debestuss
22
08-04-2005 09:31 AM
fatdaddy
12-28-2001 04:52 PM
thenkel2
03-27-2001 03:36 PM
bigsnag
17
03-07-2001 06:48 AM
