position of the rotor at TDC
Old 07-31-2012, 06:22 PM
FordmanShane's Avatar
FordmanShane
FordmanShane is offline
I need to know the approximate position of the rotor at TDC, TIA..
Old 07-31-2012, 06:26 PM
FordmanShane
should be at 1 right?
Old 07-31-2012, 06:41 PM
OldStyle's Avatar
OldStyle
OldStyle is offline
Rusty Roller
Yes, at TDC on the compression stroke of the number 1 cyl the rotor should point to the number 1 plug wire position on the cap.
Old 07-31-2012, 07:23 PM
J ballan's Avatar
J ballan
J ballan is offline
Which should point to the drivers side rear cylinder and the vacuum advance should be close to straight ahead at least on a 335 series engine anyway.
Old 07-31-2012, 07:40 PM
devino246's Avatar
devino246
devino246 is offline
Passenger's side front if no.1
Back
4 8
3 7
2 6
1 5
Front
Old 07-31-2012, 08:03 PM
J ballan's Avatar
J ballan
J ballan is offline
Back
4 8
3 7
2 6
1 5
Front
I know that would make sense to me also, but my cap was labeled with number one pointing to the drivers side rear cylinder? So I did a little research and came up with this. Crap link won't work! I'll try again.
Old 07-31-2012, 08:13 PM
J ballan's Avatar
J ballan
J ballan is offline
It's way down on the page. Couldn't get a better link. If you google it there's lots of images.
Dutch Ford and Mustang Forum - DM&FF • Toon onderwerp - 010 - TECH. INFO DATABASE: ENGINE
Old 07-31-2012, 08:32 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Disregard firing order, but everything else is the same. This is 289/302. Rotor towards #1 PLUG WIRE AS POSTED.
Old 07-31-2012, 10:01 PM
devino246's Avatar
devino246
Ah, sorry, I misunderstood your question. Yes, that sounds correct.
Old 08-01-2012, 12:52 PM
FordmanShane
Thanks again, I have everything set correctly now..
Old 08-01-2012, 04:00 PM
ranger429's Avatar
ranger429
ranger429 is offline
Figuratively speaking it doesn't matter where you have the rotor pointing, as long as the rotor is pointing to the #1 plug wire on the distributor cap it is good to go.
mj_wyoming
06-08-2010 03:48 PM
v8xploder
1978 - 1996 Big Bronco
03-26-2007 06:01 PM
eandaauto
08-08-2004 01:15 PM
PoolBoy
07-04-2004 04:29 AM
samckernan
02-06-2004 09:28 AM
Quick Reply: position of the rotor at TDC
