4R100 PWM/NON-PWM
Old 07-30-2012, 05:49 PM
mikey89014's Avatar
mikey89014
mikey89014 is offline
4R100 PWM/NON-PWM
I have a 2001 Superduty 5.4 with an Automatic. Will a 7.3 trans with PWM lockup converter work properly , if plugged into my PCM? I'm not sure if a 2001 5.4 4r100 has PWM or NON-PWM lockup. Thanks
Old 07-30-2012, 10:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
2001 is PWM.
Old 07-31-2012, 12:20 AM
mikey89014's Avatar
mikey89014
I'm hoping the gas PCM will shift it properly . If not, will I just change the pump and solenoids to the non-pwm?
Old 07-31-2012, 12:21 AM
mikey89014's Avatar
mikey89014
Thanks again
Old 07-31-2012, 09:06 AM
Mark Kovalsky
Change the case, too. A 7.3L case will not bolt to a 5.4L.
Old 07-31-2012, 04:15 PM
mikey89014's Avatar
mikey89014
Yes, thanks. I'm thinking of installing a diesel engine with my current PCM. Will the gas PCM control the transmission , properly?
Old 07-31-2012, 08:43 PM
Mark Kovalsky
A gas PCM can control a diesel transmission, as long as it is also controlling a gas engine. Without an engine to control the PCM will not control the transmission.
Old 08-11-2012, 05:16 PM
mikey89014's Avatar
mikey89014
Thanks for you help, i was hoping to modify the electronics to use the gas pcm with an IDI diesel engine , somehow.
Old 08-11-2012, 10:13 PM
Mark Kovalsky
You could get an IDI transmission controller. Or you could get a controller from PCS.
homertwo
WTB - Parts & other
06-17-2017 11:30 PM
samsulaimpala
1997 - 2003 F150
05-25-2010 03:38 PM
Hengines
1999 to 2016 Super Duty
03-01-2008 08:27 AM
ExpyBoy
12-06-2005 06:48 PM
Quick Reply: 4R100 PWM/NON-PWM
