Windshield wiper arm removal?
Old 07-29-2012, 09:09 PM
FlaresideF150's Avatar
FlaresideF150
FlaresideF150 is offline
I wanted to take my windshield wiper arms off to paint them. Ive covered everything in newspaper before and sanded them and painted them but that didnt last long so i want to take them off and sand blast them and put a few good coats of paint on. Does anyone know how to get them off without any special tools?
Old 07-29-2012, 09:20 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
From my Ford Service Manual:
Removal and Installation
1. Raise windshield wiper blade (17528) end off windshield and slide latch away from windshield wiper mounting arm and pivot shaft.
2. Unlock windshield wiper pivot arm from windshield wiper mounting arm and pivot shaft.
3. Remove windshield wiper pivot arm. Windshield wiper pivot arms can be removed and installed without the aid of any tools.
For installation, follow removal procedures in reverse order. If windshield wiper blade does not touch windshield, then slide latch is not completely in place.
The latch they are referring to is on the wiper arm itself. Once you lift the pivot arm you will see what they are talking about.
Old 07-29-2012, 09:24 PM
materthegreater's Avatar
materthegreater
materthegreater is offline
One of my wiper arms keeps falling off by itself!
Luckily it's the passenger side...
Old 07-29-2012, 09:31 PM
FlaresideF150
Are you referring to the little latch that slides uo underneath the arm that will hold it off the windshield?
Old 07-29-2012, 09:49 PM
rla2005's Avatar
rla2005
rla2005 is offline
Take a close look at the wiper arm itself. Where it attaches to the drive mechanism is a small latch. Lift up on the arm, then pull on the latch, let loose of the arm, it will rest against that small latch arm once it is pulled out. Once that is complete, pull up on the entire assembly, it will come off the pivot point.
Old 07-30-2012, 09:18 PM
FlaresideF150
Thanks that should do it. Ive always used that latch to hold the wipers off the glass when im washing my truck or cleaning the windows i never knew it was for removing it.
Tim Hodgson
22
03-21-2020 10:58 AM
1918ALF
01-01-2016 02:34 AM
mrivney
10-17-2014 02:55 PM
marvinlong
1999 to 2016 Super Duty
11-05-2006 10:52 PM
TMG2
03-01-2004 10:01 AM
Quick Reply: Windshield wiper arm removal?
