1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 F250 v10, This problem has got me stumpped
Old 07-23-2012, 04:10 PM
twanster's Avatar
twanster
twanster is offline
Does anyone have any suggestions? I Drove my pickup to work, it fired up just fine. When I started it up to head home, it sounded sluggish, but ran. About 3 miles down the road it shut off. Ended up getting towed. I've replaced the fuel filter and treated the lines with seafoam however it didnt fix it. the fuel pump whines when the key is in the on postion, and my pickup tries to turn over, its as if its not getting fuel. Help me please!!!
Old 07-23-2012, 05:08 PM
Monster-4's Avatar
Monster-4
Monster-4 is offline
Have you check the fuel pressure at the fuel rail? This will tell you if the fuel pump is dead (most likely issue).
Old 07-23-2012, 05:45 PM
twanster's Avatar
twanster
twanster is offline
thanks for the reply monster 4, and this is probably a dumb question, but how do you check the fuel pressure at the fuel rail?
Old 07-23-2012, 05:50 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
Get a fuel pressure gauge and hook It up to the schrader valve on the fuel rail. It will have a black cap that looks like a valve stem cap. Tell us what the pressure is
Old 07-23-2012, 06:48 PM
Monster-4's Avatar
Monster-4
What he said. You should have 28-30 psi at idle (also think it's the same for KOEO) and 38-40 at WOT.
Old 07-24-2012, 12:25 PM
twanster's Avatar
twanster
twanster is offline
right on ill give it a shot thanks
Old 07-24-2012, 12:51 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
VONxRUBENxLA is offline
u could also hook up a little fuel pressure gauge on there permantly if u feel it necessary
also does anyone know if a scan gauge II can read fuel pressure?
Old 07-24-2012, 01:25 PM
Monster-4's Avatar
Monster-4
SGII cannot read fuel pressure. There is no factory sensor.
e21pilot
Modular V10 (6.8l)
05-31-2018 11:17 PM
rangerlugnut
05-22-2017 12:38 AM
jonathan9573
08-07-2014 02:48 PM
popee
11-02-2011 05:29 AM
F Truck08
08-29-2011 04:33 AM
Quick Reply: 2001 F250 v10, This problem has got me stumpped
