My 50 Pontiac tail light install in 57-60 F100
Hey everyone this is what I came up with to install 50 Pontiac tail lights in my now 57 F100 ( see pics).
I used the OE tail light lense mount and cut some slots for the new tail light. I will fine tune this setup with some different springs and screws to pull it in tighter and I will cut the back off the OE assembly to allow the Pontiac tail lights wiring to go through let me know what you think I just didn't want to drill all the way through the box or have any hardware showing inside the bed.
I was going to do this in the bed ( see holes and I still might) but thought I would try this way first
Thanks
Jeff
Thanks
Jeff
Jeff,
plz tell me are the pics with the original taillight body underneath and is this the final position of the taillight ? Did you use the rubber gaskets ?
Seems I can look a bit "behind" the chrome ring. I´m in the process of fitting my 50 pontiacs and I want them a bit deeper down the opening. The bulb housing of the pontiacs seems to clear the stake pocket, guess I´ll have to cut the edge of the rubber gaskets ....
Thanks, Tom
Thanks, Tom
Jeff,
Thanks, Tom
Thanks, Tom
The pontiac lights were bought from Speedway good price and have glass lenses
Thanks
Jeff
Thanks Jeff ....
Would you mind when I show you and everyone interested my solution ?
I removed the whole OE taillight and did some cutting on the taillight mount, went the same way with long holes and springs over attaching bolts.
The new 50´s taillight fits without touching the stake pocket and sits deep inside the opening. I used the included rubber gaskets but cut the edge a bit for a better fit.
The first pic shows the taillight mount after cutting and some touch-up, second shows taillight in place.
Thanks, Tom
Thanks, Tom
Thanks Jeff ....
Thanks, Tom
Thanks, Tom
black04lariat
2004 - 2008 F150
01-07-2008 10:31 AM
