Fridge with a 460, what headers?
Old 07-16-2012, 11:58 AM
StatikPulse's Avatar
StatikPulse
StatikPulse is offline
Curious to hear what other owners with 460 run for headers? Any clearance issues or anything I should be aware of?
Old 07-17-2012, 03:23 PM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
are you running the stock or aftermarket suspension?
i have a 46o witha MII suspension and use Headman headers meant for a 77-79 4x4. the only modification i had to do was bend them out a bit to clear the steering shaft and use 2 u-joints to go around the headers. the passenger side fit perfect and both sides exits above the bottom of the frame rails so the collectors are tucked up nicely and don't drag.
if i was doing it again, i would probably spring for some block hugger headers like Sanderson makes. i think they would work a lot better with less modifications required.
rgds
Mike
Old 07-17-2012, 03:33 PM
StatikPulse
Thanks for the info Mike. I do plan on lowering, probably dropped axle, mono leaf, etc. Looking for something that will require as little work as possible to fit.
Old 07-18-2012, 12:01 AM
59 shorty's Avatar
59 shorty
59 shorty is offline
I also run the Hedman long tubes on my 429 and clearance was not an issue but be aware that with the tie rod behind the axle, clearance issues can be a problem as in the tie rod hitting the tubes when the suspension bottoms out. Mark
Amish65F100
07-11-2018 06:56 PM
william16339
12-22-2016 04:55 AM
K.Dot
10-10-2006 03:54 PM
61 uni
01-06-2005 01:57 PM
Quick Reply: Fridge with a 460, what headers?
