Went back and checked my notes, be careful with the 80s and 90s (up to 96) F250s. Some have larger diameter studs (they use the 1 1/16" across flats lug nuts) I do not know what year this started, so carefully look at the holes of the wheel. Although the bolt circle is the same, the rims have larger holes and the smaller lug nuts on the older trucks do not seat properly (too deep). I know from experience that the wheels from a 1990 F250 will fit over the studs on a 59 F250, but the lug nuts for the 1/2" studs engage the taper in the holes with the corners of the hex, not the taper. Not good.
Thanks 3414/ND for yall's help- I appreciate the needed info- I don't want the wife takin a swing at me for seeing yet Another 250 wheel behind the garage- see you on the forum
