3 speed manual transmission parts
I will have a complete stock 3 speed from a 60 along with clutch, etc available in a couple weeks. A guy is buying the motor and doesn't need the transmission. Everything is installed and running now. After the engine sells I have a drivetrain transplant planned.
Anyway - If you want a complete working one instead of rebuilding your current let me know. Location is in MO so shipping might be more of an issue than something closer to you.
There are 3 different low/reverse gears, specific either to 223 or 292. Count the number of helical teeth, will be either 23, 28 or 32.
COAR-7111-A (replaced B5A-7111-A) .. Countershaft / Obsolete
PARTS INTERNATIONAL in Farmers Branch TX has 2 = 888-727-0418.
ANTIQUE AUTO SUPPLY in Arlington TX has 4 = 817-275-2381.
KINSEL L/M in Beaumont TX has 4 = 800-816-2894.
WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 18 = 800-543-4959.
B-7140-A .. Reverse Idler Gear Shaft / Obsolete
TISON MOTOR CO. in Estill SC has 2 = 803-625-2551.
PARTS INTERNATIONAL has 4.
GREEN SALES has 23.
COAR-7141-C (replaced MB-7141-A, B6C-7141-A, B9TR-7141-A, COTR-7141-A) .. Reverse Idler Gear & Bushing / Obsolete
ANTIQUE AUTO SUPPLY has 1.
WESLEY OBSOLETE has 5.
GREEN SALES has 24.
The following should also be replaced. May be available from NAPA
3) C3AZ-7A044-A (replaced B1AZ-7A044-A) .. 2/3 Syncro Shoe / Obsolete
GREEN SALES has 15.
PARTS INTERNATIONAL has 50.
2) C3AZ-7107-C (replaced B1A-7107-C) .. 2/3 Syncro Brass Blocker Ring / Obsolete
DOTTS MOTOR CO. in Clearfield PA has 3 = 814-765-9681.
GREEN SALES has 7.
B6TZ-7B331-C .. Small Parts Kit (snap rings/washers etc) / Obsolete
GREEN SALES has 15.
COAZ-7100-A .. Low/Reverse Gear-28 helical teeth / Obsolete
SOEBY MOTOR CO. in Walhalla ND has 1 = 701-549-3711.
AITKEN MOTOR CO. in Aitken MN has 1 = 218-927-2169.
NORTZ & VIRKLER FORD in Lowville NY has 1 = 315-376-6594.
WESLEY OBSOLETE PARTS in Liberty KY has 7 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 24 = 800-543-4959.
Call around for the best price on each part. Obsolete parts prices vary wildly from one source to another.
lmdew
08-01-2016 09:10 PM
995.4SD
07-19-2011 09:03 AM
