Front end knocks when truck rocked.
Please Help!
I have a 2005 F150 FX4 w/the 5.4 motor. I have been noticing a knocking noise when i go over bumps but can't figure it out. The same noise occurs when I grab the top of the front right or left wheel and push in and out. The truck will rock back and forth and this re-creates the noise. For some reason the noise sounds like it is coming from the engine bay area. Any help would be greatly appreciated. I can also get a video of it if you would like.
Thanks in advance!
Morgan
Thanks in advance!
Morgan
I checked them and there was no play in the lins.. I felt no play in any suspension parts. Like I said before it sounds almost like the sound is coming through the fender wells. I can push up and down on the suspension and no knows. I only get the knock when I am rocking the truck from left to right via the wheels.
Here is a video of the noise. It is actually making two different types of noises now. One has a deeper sound and the other has a more metalic sound.
05 f150 suspension noise - YouTube
Without watching your video,will do later. I would check your upper ball joints. Just aguess.
