390 4x4 headers???
Old 07-02-2012, 08:48 PM
FossenRacing's Avatar
FossenRacing
FossenRacing is offline
390 4x4 headers???
any one know of a good set of fe 4x4 headers?
i bought a diy headers but lack the time to build them cause i am by no means a exhaust man.
i want 2 inch primaries into 3.5 collector. if a set that had a primary length of 32-36 inches would be ideal.
Old 07-02-2012, 10:13 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Mad Dog Headers
F-150-350 4WD 1973-79<?XML:NAMESPACE PREFIX = U1 /><U1:P></U1:P>
Part #9228 - 390/428 engine, 2" primarys, 3 ½" collectors, fenderwell exit.<U1:P></U1:P>
450.00
Old 07-02-2012, 10:25 PM
BlueOvalDismantlers's Avatar
BlueOvalDismantlers
BlueOvalDismantlers is offline
I have 2 sets of FE headers, and will be selling a pair cheap if you are interested... PM me
Old 07-03-2012, 10:37 AM
garthneddy's Avatar
garthneddy
garthneddy is offline
You must have alot of motor to be needing 2 inch primaries. I think that most of the headers out there will fit well, especially considering i had a set of cheap flowtechs on my 76 and they fit perfectly
Old 07-03-2012, 05:57 PM
NW 150's Avatar
NW 150
NW 150 is offline
Old 07-03-2012, 06:41 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
I bought a set of Sanderson headers (PN FF427) for my 2wd 360FE Bumpside project...3/8-inch flanges at the head and collector and made in the USA . Plain steel for $325 or ceramic coated for much more.
They'll fit a 4x4 too and ya don't have to jack up the engine to install or remove them!
These are ceramic coated:
Old 07-03-2012, 08:12 PM
FossenRacing
I would say than I have enough motor. Its a stock stroke and bore 390. That's camed to just pull 16 inches of vacuum. (rules)
Head modification is forbidden but port matching the intake to the head is not.
And all the 1 3/4" primary headers have to small of ports for the d2te head. Needs to have a bigger port than the head to prevent reversion.
I just need a good fenderwell header to finally run a collector as there is no room for one inside the frame.
I learned that the hard way when the yoke on the driveshaft smashed the collector and destroyed the driver side header.
Since I am the only one in the club running a fe, I have to have my engine preform at its best.
And my ford builders book is saying to run 2 inch primaries 32 to 36 inches long into a 3.5 inch collector into a pipe that's 18 to 20 inches long and then have a bent dump tip.
And aim it 45 degrees out and it will have a mean rap.
Old 07-03-2012, 08:19 PM
650's Avatar
650
650 is offline
Originally Posted by NW 150
That seems pretty cheap for a set of headers. When you put them on did you have to heat tape wrap the starter to insulate it from the headers?
Old 07-03-2012, 09:12 PM
garthneddy's Avatar
garthneddy
The headers NW 150 posted a link too are the ones i have used as well, they fit great.
Old 07-03-2012, 09:33 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
They arent fenderwell exit, correct? Did you have to modify anything to get them to fit?
Old 07-03-2012, 10:10 PM
garthneddy's Avatar
garthneddy
I didnt have to modify a thing when i was running them. It was 100% bolt on
Old 07-04-2012, 08:50 AM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Originally Posted by montana_highboy
Mad Dog Headers
450.00
The only fenderwells I'm aware of. Just now getting them installed.
Old 07-04-2012, 09:44 AM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Looks like a quality set there Grinner.
Old 07-04-2012, 01:13 PM
74ford4x4's Avatar
74ford4x4
74ford4x4 is offline
If you got the money, I get the sandersons or mad dogs cant be the quality and the looks. I put a set of flowtechs and they work and fit pretty good, but they dont look as pretty as sandersons or the mad dogs.
Old 07-11-2012, 07:18 PM
FossenRacing
called and ordered a set of these last week and called today and mark was just finishing them. hopefully customs doesnt hold them back to long.
have a mud race in 3 weeks and want them on there by then
Quick Reply: 390 4x4 headers???
