Info help on '59 Ford F250
Old 07-01-2012, 10:03 AM
Kris23's Avatar
Kris23
Kris23 is offline
My father has a 1959 Ford F250. He is only the second owner of the truck and he was told that the engine is original along with the current listed mileage. He is wanting to sell the truck but is unsure of the engine size. I listed it for him on craigslist just to see if he received any interest. An individual told us that the engine is not the original as the picture we listed showed the distributor in the front but for this model and year, the only V8engine available in the '59 was a 292 Y block which has the distributor in the rear of the engine and not the front.
I just wanted to get some honest insight from people that know what they are talking about. I can get you some pics if needed to answer correctly.
Thank you
Old 07-01-2012, 10:24 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Yep, Y blocks distributor is in the rear!
Of course we need pictures!
Old 07-01-2012, 10:42 AM
Kris23's Avatar
Kris23
Kris23 is offline
<!-- START CLTAGS -->
This is what I have of the engine. Hope it helps a little. I will be getting better ones within the next few days.
Thanks for your help.
Old 07-01-2012, 11:43 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Definitely not Y block valve covers, not sure what you have by that picture.
Old 07-01-2012, 11:48 AM
theodore/teddy
Refyred
Well, marvin looks good for his age but his not original. Got a newer engine and a 1960 hood. The radiator is newer also. I'm not the one to id the engine but if you find some numbers on the block and heads, surely some here can id it for you.
Old 07-01-2012, 11:57 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
From what I can see in the pic it looks to be an FE. Could be a 352,390,360 or a few others. Without a bore and stroke you probably wont know for sure.
Old 07-01-2012, 12:18 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,451 Likes on 1,398 Posts
I agree it's an FE series engine and from the valve covers I'd guess late 60's. Most likely a 390 but there's no way to tell for sure certain. The Carter/Edelbrock carburetor is not stock, either. How long has your Dad had it?
Old 07-01-2012, 12:42 PM
Kris23's Avatar
Kris23
Kris23 is offline
Thanks to everyone for all of your input. It is helpful!
<TABLE class=tborder style="BORDER-TOP-WIDTH: 0px" cellSpacing=1 cellPadding=6 width="100%" align=center border=0><TBODY><TR title="Post 12013309" vAlign=top><TD class=alt2 align=middle width=125>52 Merc</TD><TD class=alt1>I agree it's an FE series engine and from the valve covers I'd guess late 60's. Most likely a 390 but there's no way to tell for sure certain. The Carter/Edelbrock carburetor is not stock, either. How long has your Dad had it? </TD></TR></TBODY></TABLE>
Dad has had the truck for at least 15 years that I can think of. He is only the second owner and was apprently given some false info on it as he was under the impression that it was basically all original.
When I was there visiting, we tried to look for some numbers so that I could research it some for him before listing it for sale but we were not able to find any numbers on it whatsoever.
All of your added input is extremly helpful when trying to sell it. I appreciate your help.
Thanks
Kris
Old 07-01-2012, 01:04 PM
99hosss's Avatar
99hosss
99hosss is offline
Not sure about a 59 but that lightning bolt on the hood should signify a 6 cyl. motor uder the hood as original
Old 07-01-2012, 01:46 PM
theodore/teddy
Refyred
Kris there should be a data plate on the inside of the glove box door or possibly driver side door jam. That would show year, model plus what the truck came with and should match with the vehicle identification number on the top frame rail behind the front axle in front of the cab, below the battery!
creator
04-24-2014 08:39 PM
Kris23
07-01-2012 10:37 AM
B 3000
Ford Truck Parts for Sale
11-08-2011 06:53 PM
tomrooster-1
Flathead V8 & Flathead 6
03-10-2006 09:49 PM
wfo4me
12-16-2005 09:14 PM
Quick Reply: Info help on '59 Ford F250
