Towing a big RV
Old 06-28-2012, 06:05 PM
thinksnow's Avatar
thinksnow
thinksnow is offline
Towing a big RV
I've been shopping for a used RV. The one I'm currently considering is 32ft coming at 7900 lbs dry. Its GVW is 9600 lbs, just over what my Expy is rated for. Although the tires I have on it have a higher max capacity then the OEM tires so I think it will take it. I'm pretty sure the truck will be an absolute dog with that much weight so Im planning on getting a tuner and tunes from 5 star tuning. Has anyone else had any success or failure with a trailer this big?
Old 06-28-2012, 06:44 PM
berry1234's Avatar
berry1234
berry1234 is offline
Don't do it. A tune will not make up for the amount of weight you are towing. You need a diesel.
Old 06-28-2012, 06:51 PM
thinksnow's Avatar
thinksnow
An F250 diesel is my other vehicle but even with the crew cab I don't have enough seats for all my kids; ths we have an Expy EL
Old 06-29-2012, 02:12 PM
crn808's Avatar
crn808
crn808 is offline
Not that its recommended but I occasionally tow over the 9100lbs. IF you do, its at your own risk.... make sure you have a weight distributing hitch and that you have load range D or E tires with 60+psi. I find that with my Expy its not so much the total weight but the tongue weight as the independent rear sags out a good bit. I tow my rock buggy out to moab from denver truck and trailer about 9700lbs. it does very well, not a speed demon up the passes but still 50MPH or so. i avg 10.5mpg while towing that load. I also do not run a programmer as I find most just add fuel and raise rev limiter. I don't want it to work harder in those situations.
Old 06-29-2012, 02:36 PM
berry1234's Avatar
berry1234
Go with a smaller, lighter trailer. Expy is not the right vehicle to max out the towing capacity.
astepatatime
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
02-21-2016 10:32 AM
sonar_91
11-06-2011 06:57 AM
Chief-e9
Fifth Wheel & Gooseneck RV Towing
08-25-2011 04:17 PM
Jarniscipus
02-20-2011 01:01 AM
delornut
2009 - 2014 F150
11-22-2010 02:44 PM
Quick Reply: Towing a big RV
