socket size for lug nut
Old 06-28-2012, 10:21 AM
macguy's Avatar
macguy
macguy is offline
what is socket size for lugnut on F250 6.7? I want to torque my wheels with 1/2 drive, but need socket size to buy.
Old 06-28-2012, 11:20 AM
jlalanas's Avatar
jlalanas
jlalanas is offline
I think it's 13/16 or 15/16, can't remember exactly.
Old 06-28-2012, 11:55 AM
PITS's Avatar
PITS
PITS is offline
You can use a 13/16"
Old 06-28-2012, 12:22 PM
720Deere's Avatar
720Deere
720Deere is offline
Actually it is none of the above. You guys need to accept that 90% of the hardware on these trucks is metric including the lug nuts!
Old 06-28-2012, 12:24 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 6,972 Likes on 2,190 Posts
I don't have stock tires, so I don't know the size. However, why make this statement and not provide the correct size then?
Old 06-28-2012, 01:04 PM
jlalanas's Avatar
jlalanas
jlalanas is offline
Think it might be 22mm, but 13/16ths works just as good.
Old 06-28-2012, 01:17 PM
PITS's Avatar
PITS
PITS is offline
Technically it's a 21mm. A sloppy 13/16" will work just fine.
Old 06-28-2012, 06:04 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
I use 21mm, it fits properly. I also have far more metric socket sets than SAE sockets kicking around.
Old 06-28-2012, 08:26 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
I use a 21mm socket. 3/4" drive. Nice good hold on that sucker and it's much easier to deal with. 1/2" drive just won't do......
Old 06-29-2012, 06:03 AM
PumpDoctor's Avatar
PumpDoctor
PumpDoctor is offline
What are the lug nut torgue specs on the SRW. All I saw in the manual was 95ft lbs for F350 DRW. Is it the same for all Superduty trucks.
Old 06-29-2012, 06:58 AM
jlalanas's Avatar
jlalanas
jlalanas is offline
I thought it was 165lbs......
Old 06-29-2012, 08:48 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
Sounds right j. I put my hand about 16" toward the end of my ratchet and apply most of my weight (175) which should net me about 165 ft-lb of torque on them. I worked it out years ago and don't think about it anymore.
Old 06-29-2012, 09:26 AM
Glockin' Bob's Avatar
Glockin' Bob
Glockin' Bob is offline
165 ft/lbs is the spec in my owners book. I tighten mine with a 1/2" drive torque wrench, 21mm socket sounds right. I rotate the tires (SRW) every oil change which I do myself.
garbhead
12-02-2013 10:55 PM
Truck Guy99
10-17-2013 06:41 PM
Rollie 1
04-12-2010 08:08 PM
cjsimp1
02-20-2007 08:43 PM
echoy97
Escape & Escape Hybrid
09-23-2004 10:53 AM
Quick Reply: socket size for lug nut
