School me on heaters
Old 06-25-2012, 09:11 PM
blackedout's Avatar
blackedout
blackedout is offline
I have a 59 I'm working on. The PO removed many unnecessary things like windshield wipers, a proper fuel tank, rear brakes, and a heater. Or so I believe, I have no idea if one was even installed from the factory or if this was an option. I don't even understand the vents in the kick panel. Any info would be greatly appreciated.
Old 06-25-2012, 11:12 PM
99hosss's Avatar
99hosss
99hosss is offline
Hey Blackedout, I just bought a 60 250, will trailer it home tom., let you know about the vents soon. - I think you should see 2 holes in the firewall where the heater hoses went- right beside pass side hood hinge area
Old 06-26-2012, 04:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Heater/defroster optional thru 1966, there were two types, fresh air or recirculating.
1957/60's have fresh air vents operated by cables with ***** on them. 1959/60's use specific right/left cables, while 1957/58's are the same right/left.
Old 06-26-2012, 04:37 AM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
As stated by, 99Hoss, look for Holes in the Firewall where the Heater should have been mounted.
What Number Dummy wrote.
The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen behind the back of the Hood.
They open & close w/ the Vent Pull ***** mounted in the Dash, one on either side of the Steering Wheel.
Old 06-26-2012, 09:32 AM
NumberDummy
The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen (windshield) behind the back of the Hood (Bonnet).
"The US and Great Britain, two nations separated by a common language." -George Bernard Shaw
Old 06-26-2012, 11:29 AM
blackedout's Avatar
blackedout
thanks for all the respones. I saw where the holes should be but haven't been punched open which leads me to believe there never was a heater/heater core installed on my truck. That would make sense originally being an Arizona truck.
Now to the air vents, do they bring in air from the engine compartment? How does one get warmth if not?
Old 06-26-2012, 11:52 AM
3414's Avatar
3414
3414 is offline
The fresh air comes from the base of the windshield. You only get warmth on hot days. You get cold on cold days.
Old 06-26-2012, 02:07 PM
Col Flashman
Once Again! The Louvers in the Kick Panels are the Fresh Air Vents for the Grill mounted in front of the Windscreen behind the back of the Hood.
troymn
11-16-2017 09:47 PM
drfelgood5
17
10-10-2008 06:34 PM
germchef
02-03-2007 09:36 AM
randylay
10-18-2004 10:58 PM
capo88
03-30-2003 01:01 PM
Quick Reply: School me on heaters
