power to manual window conversion
Old 06-25-2012, 08:51 PM
bikeymikey's Avatar
bikeymikey
bikeymikey is offline
Just trying to figure out if this is the route i wanted to take. i've done a search and read up on the threads regarding this subject, i probably will try to rebuild the motors on the windows for my '89 4 door f350 4x4. but just in case that doesn't work out, i'm wondering if i can take a manual window regulator plus the interior panel off of any f series truck or does it have to be from a 4 door f350? i understand that some parts of the panels might not match up with the dash if they're from a different generation truck.
thanks!
Old 06-26-2012, 08:00 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,108 Likes on 2,168 Posts
all you really have to do is drill a hole for the hand crank and leave the switches there till you find manual door panels.
as for the regulators, remove the power ones and replace with manual ones.
Old 06-26-2012, 08:07 AM
pfogle's Avatar
pfogle
pfogle is offline
I think the easiest way would be to find manual doors at the boneyard.
Old 06-26-2012, 01:34 PM
bikeymikey's Avatar
bikeymikey
that sounds like a good plan
if i went this route, does the donor vehicle have to be a 4 door f350? or are the front doors all the same? i have an 89
Old 06-26-2012, 01:37 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
Not trying to hijack, but can the same be said for the reverse? I have 94 XL with manual windows. Is there existing wiring in the door of my XL manual window doors? Can I get the motors, regulators and swithes from XLT door and plug n play?
Old 06-26-2012, 02:10 PM
jas88's Avatar
jas88
jas88 is offline
The wiring for pw is not there on manual window trucks so it is not plug n play.
Old 06-28-2012, 12:31 PM
bikeymikey's Avatar
bikeymikey
still trying to figure out if the interior door panels of any f series truck will fit on the door of my 89 4 door f350.
Old 06-28-2012, 01:24 PM
tjc transport
i ain't rite
87 to 91 f-series and bronco will exact fit.
92 and newer will sorta fit, but not exactly
Quick Cal
1999 to 2016 Super Duty
05-15-2018 07:45 PM
pdqtimetrialer
07-07-2016 04:44 PM
chopped&dropped
1997 - 2003 F150
04-20-2011 08:17 PM
kjg26
09-11-2006 08:38 AM
Quick Reply: power to manual window conversion
