newbie here just bought a 58'
Welcome to FTE!
Congrats on your '58. We had a '58 F600 on the farm, and I have always liked the look of those.
Your trans is non-synchro in first gear, and thus it will grind, even at a standstill. You will not be able to easily downshift it into first either, although with enough practice and rev matching, it can be done.
Try shifting it into 3rd, then 2nd then 1st when at a stop, or at least 3rd then first. This will stop all motion inside the trans. (the input shaft spins due to friction from the pilot bushing and sometimes a little clutch drag)
I'd say try 2nd, but remember, the 2nd gear synchro leads a tough life, so best try not to use it just to "still" the trans to make first easier to engage.
Good luck with it!
Good luck with it!
Your bell to trans is a "square", thus you need a trans with that square, or a later one that is drilled for both.
These are BW T85, 86, 87 model transmissions iirc, so those would be ones to look for.
If you are looking for a different trans, the T98 will have the square pattern also. Some other later transmissions have both patterns or can be drilled for the older pattern.
https://www.ford-trucks.com/forums/1...nsmission.html
There was a light and heavy in the F250, so you might look for the T89 also.
The Ford "303" top loading 3 speed came out in '63.
It may have had both patterns in the first few years of production. Not sure on that. When you are trans shopping, the difference in patterns will be clearly visible. There is a comparison here, with a trans that has both patterns:
Toploader Imposters
More trans decode info here:
https://www.ford-trucks.com/forums/1...ease-help.html
Picture of the 303 3 speed--very easy to ID without removal:
http://www.google.com/imgres?q=ford+...:16,s:15,i:175
Tin cover and two shift arms are the main clues. Note this one has a Mustang or Cougar floor shifter on it. Column shifter arms are different.
Warner T-85 is an overdrive transmission. wasn't available until 1965, F100's only.
1957/60 F100: TRANS code stamped on Rating Plate:
A = Ford 3 speed manual light duty (no first gear syncro) / B = Warner T-86 3 speed manual with overdrive (no 1st gear syncro) / F = Warner T-98 4 speed manual / G = Ford-O-Matic (w/a 223 I-6).
Ford type 3.03 3 speed manual all syncromesh trans introduced in 1963.
ABH
09-08-2018 03:48 PM
kbddbd
06-05-2005 06:20 PM
