Expedition Towing Capacity
Old 06-22-2012, 10:05 AM
EXP BMW's Avatar
EXP BMW
EXP BMW is offline
I'm attempting to tow a car trailer with a car about 2000 miles........all told, close to 6,000 lbs. Will my 08 Expedition do this? Don't have the heavy duty tow package but was thinking I'd add a transmission cooler and brake controller. Any advice?
Thanks.
Old 06-22-2012, 12:10 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I'm thinking you'll be just fine.
Old 06-26-2012, 01:01 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Brake control is a must, and a legal and moral requirement. Transmission cooler on the 08 is not larger on the HD tow packge, but the radiator has more fins. you should be fine since a car on a trailer doesn't have the large aerodynamic profile of a travel trailer.
Old 06-26-2012, 02:31 PM
cstanley44's Avatar
cstanley44
cstanley44 is offline
I pulled the trailer and Buick in the picture below 700 miles from TN to FL without any issues
The u-haul trailer had a built in brake in the tongue of the trailer.
It pulled beautifully, even though the trailer says 'max 55' I did a little more than that. Averaged 60-65 probably.
It was an effortless trip.
Old 06-29-2012, 02:19 PM
crn808's Avatar
crn808
crn808 is offline
You will be just fine, i tow my rock buggy (9700 with trailer) with my 07 and have no issues. I do have E rated tires as well as weight distributing hitch and of course trailer brakes. also take your time, dont keep engine at red line a long time and avoid excessive transmission shifts by manually shifting when you are going up or down large hills
Old 07-19-2012, 09:30 PM
03 SVT VERT's Avatar
03 SVT VERT
03 SVT VERT is offline
You're good. Maximum weight carrying capacity for an Expedition is 6,000lbs and that's the same for all version regardless of 2wd/4wd, axle ratio, or tow package.
Old 07-20-2012, 06:04 AM
chuck s's Avatar
chuck s
chuck s is offline
The '07 HD Tow package has a larger than stock transmission radiator. Looks the same size as the standard one but is thicker (or something). Part numbers are definitely different. Unaware the '08s come standard with the HD transmission radiator. Can't tell by just looking unless you read the part sticker.
No mechanical changes with HD Tow, just better engine and transmission cooling. Standard Ford parts if you want to upgrade. Labor is probably the big cost.
Only other change in HD Tow is the full wiring with the connection for electric brakes. The "blue brake wire" should be there at the back of the truck (blunt cut, dipped and taped) even with the standard tow package and there's a kit to fit the round 7-pole electrical connector. The electric brake connector is under the dash behind the CAN connector.
The receiver "may" be upgraded with HD tow, the documentation is silent. Class 4 with HD tow.
-- Chuck
74Mav
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
16
05-18-2017 06:27 PM
kcallis
07-18-2014 12:16 AM
expguy121
06-07-2012 08:20 AM
IowanStraight6
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-01-2009 10:19 AM
ryn6609
2004 - 2008 F150
04-01-2005 08:16 PM
Quick Reply: Expedition Towing Capacity
