Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Help with vortech supercharger belt squeal...
Old 06-21-2012, 06:34 PM
jhaas63's Avatar
jhaas63
jhaas63 is offline
I just changed the belt on my vortech supercharger and it squeals when you floor it. I got the truck with a badly worn belt on there and that one squealed too. I thought the new one would help. It doesn't matter if I loosen it or if the belt is tensioned all the way down, it still squeals when you get on it. Thoughts?
It's on 93 Lightning btw.
Old 06-28-2012, 07:44 PM
jhaas63's Avatar
jhaas63
jhaas63 is offline
No? Ok.
Old 06-28-2012, 09:11 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I'd check the pulley alignment first; using a straight edge to see if the front of the crank pulley is even with the front of the blower pulley.
Are you sure it's not coming from the accessory drive belt?
Old 06-29-2012, 03:55 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
There is spray belt dressing to make a belt grippier. With belt off, check your bearings in the charger and also in the tightener. Check your other belt also like above. X2
Old 07-02-2012, 12:02 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
+1 There!!!!!!!!!!!!!!!!
also, if all checks out ok, if not using, switch to Goodyear Gatorback belt
if ok there, visit a real hardwrae store, this is a "stick" that is used to rub on the wood surfaces of door jambs to address weather-induced sticking/squeeks....it is not a lubricant but it works well on squeeky belts and does not cause any damage like the "belt dressings" and other "anti squeek belt sprays" do.
Old 09-07-2012, 11:28 AM
Poolshark1321's Avatar
Poolshark1321
Poolshark1321 is offline
Goodyear Gatorbacks are great... you said it only happens when you floor it. Possibly slipping belt?
Tony2847
Escape & Escape Hybrid
09-10-2018 01:14 PM
Dennis Anderson
1999 to 2016 Super Duty
12-17-2014 04:46 PM
DGM
05-17-2012 07:36 PM
GR854
05-11-2006 04:04 PM
cmoore99
01-29-2005 09:45 PM
Quick Reply: Help with vortech supercharger belt squeal...
