1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
5.4L Rough Idle - EGR block off didn't fix
Old 07-31-2012, 06:08 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Hrm....I wonder if this could be a problem?
Old 07-31-2012, 07:49 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
GAH!!! Replaced the plug and cleaned the junk of the COP of #6 and now #3 is the PITA...pulled that COP and the same issue, it's sitting in a puddle of water and the plug is corroded. Needless to say time for a full plug replacement.
Old 07-31-2012, 08:33 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
You must have a source for water to drip onto the plugs to cause that much rust. I suggest that you close the hood and spray a lot of water in the area of the cowl and hood and then check inside to see if there is a trail showing where the leak is. Then you can seal that area or find a way to divert the water away from the cops.
Old 07-31-2012, 09:28 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Yeah odd thing is we haven't had any rain for weeks now and everything looks fine hood wise...one would think it would have evaporated. Coolant level looks fine so I'm not worried it's coming from the other direction.
EDIT: There was a small puddle in the #6 surrounding the plug and the #3 coil came out wet. There's also about 1/2" of built up dirt surrounding each COP.
Old 07-31-2012, 10:23 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
There's a heater hose in the area of cylinders 3 & 4 that has been know to drip coolant into these two spark plug wells.
Old 08-01-2012, 01:28 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Thanks I'll check that guy out. But it doesn't explain the water in #6. I'm wondering if its stuff that might have been there from the winter (before the problem started) when I might have goofed off in some big puddles.
Old 08-01-2012, 01:35 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Just got #3 out and it had a lot more rust on the tip than #6 did. So I think I my adventure has been a collection of problems.
Old 08-02-2012, 11:05 AM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
....and #7. I'm replacing the rest this morning but it seems as though my problems have been fluid and corrosion on top of the DPFE failing. There is no vacuum leaks..yet.
OH! One fun thing, when you pull the big vacuum hoses to work on the #6 or #7 (in my case), make sure you plug them back in before you test to see if everything is working. My reaction when the engine would just die was "great, what'd I screw up while fixing this thing!?!" then I saw I left them loose. HA!
Old 08-02-2012, 07:48 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Originally Posted by Spaded_Z
.There is no vacuum leaks..yet.
Been there, done that! Didn't like it.
If you have the vacuum lines crossed going from the exhaust manifold to the EGR sensor you will get some strange codes and the CEL will come on.
Old 08-02-2012, 10:03 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Yeah I'll bet!
Old 12-31-2012, 12:47 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
So the problem surfaced again and my new plugs are corroded as all heck. I finally thought things through. It's not water in the plug wells...it's coolant. Intake manifold gaskets are leaking.
New weekend project.
Old 12-31-2012, 12:55 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Sorry to hear that! Good luck with it.
  #28
Old 01-06-2013, 08:24 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
I'm taking my time, 6.5 hours and it's all apart. Inspecting the crossover and intake manifold. The seals were toast. I will go at the intake tonight/tomorrow and see if I can get away with just cleaning/new gaskets.
  #29
Old 01-14-2013, 02:01 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Nope, cracked at the crossover on the passenger side. Dorman IM ordered and expected tomorrow for installation. It will be nice to have this thing usable again.
  #30
Old 01-22-2013, 03:28 PM
Spaded_Z's Avatar
Spaded_Z
Spaded_Z is offline
Well that was no joy. Dorman came and was broken on one of the fuel rail towers. Had to order a replacement. Took my time putting it all back together and she's happy for now but only about 100 miles on it since the install.
It's quite nice to feel normal acceleration again.
Thedonk
02-16-2016 05:40 PM
MyKidsToy
Modular V8 (4.6L, 5.4L)
08-15-2012 04:49 PM
Carlos2
1997 - 2003 F150
03-13-2012 07:49 PM
StumpPullerF1
02-22-2011 08:15 AM
rpford
1997 - 2003 F150
01-03-2007 10:36 PM
Quick Reply: 5.4L Rough Idle - EGR block off didn't fix
