Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
07 Freestyle Battery Issue
Old 06-21-2012, 03:10 AM
ford #7's Avatar
ford #7
ford #7 is offline
I have a 07 Freestyle SEL with just over 80k miles on it. I love the car and fortunately have not had any issues out of it. The only problem i have so far is the positive battery terminal corrodes really bad. I can clean it up and a few weeks later more corrosion is built up again so bad that you cant see the terminal on the battery. What is causing this and what do i do about it? I have already tried putting dielectric grease on the terminal but that hasnt helped any.
Any thoughts?
Thanks.
Old 06-21-2012, 03:19 AM
SuperDuty_Dude's Avatar
SuperDuty_Dude
SuperDuty_Dude is offline
do u have still have warranty if you do ford will change harness and check your battery for any cracks
Old 06-21-2012, 03:34 AM
ford #7's Avatar
ford #7
ford #7 is offline
I do not believe so. I bought it used from a local small town used car lot.
Old 06-21-2012, 03:40 AM
SuperDuty_Dude
well if you dont check your battery for any cracks or leaks near the terminal go to your local ford service and ask how much new battery terminal harness is.
Old 06-21-2012, 03:48 AM
ford #7's Avatar
ford #7
ford #7 is offline
ok. will do. I have just never seen that before. The car starts up just fine and has no issues. I just want that fixed. If I remember right the battery is the original motorbraft too.
Old 06-21-2012, 03:56 AM
SuperDuty_Dude
YES IT IS I HAD THE SAME PROBLEM IN MY 2005 EXCURSION THAT I BOUGHT OUT IN COLORADO BUT SINCE IT HAD NO WARRANTY I PAID ABOUT $350 TO REPLACE THE HARNESS
Old 06-21-2012, 03:58 AM
SuperDuty_Dude
WHEN YOU GET A CHANCE CHECK OUT MY TRUCK IN MY GARAGE AND LEAVE A COMMENT ON WHAT YOU THINK ABOUT IT THANKS =)
Old 06-21-2012, 04:01 AM
ford #7's Avatar
ford #7
ford #7 is offline
ok. thanks for the advice. I will check that out.
Avanti
Escape & Escape Hybrid
12-21-2019 12:28 PM
GreatNorthWoods
01-25-2019 07:07 AM
HouseMouse
2017+ Super Duty
10-16-2017 11:16 AM
ROBBINthaHOOD
02-24-2013 08:23 PM
76supercab2
Electrical Systems/Wiring
04-20-2004 11:50 AM
Quick Reply: 07 Freestyle Battery Issue
