6.2L V8 Discuss the 6.2L V8
Towing question
Old 06-17-2012, 10:00 PM
StnrA's Avatar
StnrA
StnrA is offline
Towing question
Just got my new 250 6.2L, and am a month out from a long haul with my TT.
Should I drive in "D" tow/haul mode or use "M" and shift on my own?
Any help would be greatl appreciated.
Old 06-17-2012, 11:21 PM
rkmfordman's Avatar
rkmfordman
rkmfordman is offline
just try em all and see which suits you i like the tow haul feature but sometimes it will downshift too much when u get on the brakes hard and result in some crazy 6000+ rpm engine revs. manual is great if u want to fool with it
Old 06-18-2012, 10:30 AM
8iron's Avatar
8iron
8iron is offline
I use D in Tow/Haul mode...if it's hilly or gentle grades I will lock out 6th or even 5th gear to reduce shifting. I have used M for challenging grades but it's more of a pita than it's worth for me.
Old 06-21-2012, 01:03 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
I use tow/haul mode in the city and when in traffic. But go to just regular when on the highway, sometimes if it is hilly I will lock out 6th gear too. I never use the M mode, seems to be to much work while towing, that's why I got the automatic, the computer is very smart.
Old 06-21-2012, 01:58 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
The majority of my towing could probably be done with an F-150, so I'm not really working the truck hard at all. T/H works fine for me.
Using T/H at the last Ohio meet (15k lb trailer) the thing would not get out of first gear with the throttle pegged while going uphill. This last trip, pulling 16,500lbs on the same hill wide open, I used M and popped it into 2nd around 5500-6k rpm. No problem whatsoever, my timing and speed was much better in this case since I had full control over it, but this type of towing is a rare circumstance for me (annually at this point).
Since the truck is new to you, I'd leave it in T/H while you get used to how the truck reacts pulling the trailer. Let the truck do the thinking!
Old 06-24-2012, 02:20 PM
abendx's Avatar
abendx
abendx is offline
Just finished up my first tow with my new truck.... about 8500# bumper pull over and through many mountains on an 800 mile trip. I found that DRIVE with the T/H button depressed worked really good with two exceptions. Running up a hill, the computer is too aggressive IMO and would rather run the rig at 4500-5000 RPM to keep the speed (cruise on) than to adjust five MPH slower and keep a more desirable gear and RPM for the grade (~ 3000 RPM).
I played a bunch with the M mode and found it, as others have chimed in, too much trouble for normal driving, but.... on an extreme grade, using the M mode made life much more enjoyable and It was the only stretch of my trip that I thought a diesel would have been a better choice. These new motors are pretty good pullers!
Old 06-24-2012, 04:08 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Glad you had a good trip. These trucks make towing a lot more relaxing and you can actually use one hand on the steering wheel.
Midnightmoon
2015 - 2020 F150
18
02-18-2019 10:44 AM
natpark
2017+ Super Duty
02-22-2017 04:02 PM
jdadamsjr
1999 to 2016 Super Duty
60
03-03-2014 10:37 AM
hubler13f
08-05-2012 01:50 PM
jmo1979
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-26-2006 09:36 AM
Quick Reply: Towing question
