AC compressor will not come on.
Old 06-13-2012, 04:32 PM
pecanflyboy's Avatar
pecanflyboy
pecanflyboy is offline
I've read a lot about this issue, but can't figure it out.
2003 F150 SuperCrew 5.4L, 4X2
Air Conditioning worked perfectly last night. Nice and cold.
This morning, no worky. AC compressor clutch is not engaging.
Here is what I've done, engine running, Max AC, clutch will not engage compressor:
  • Jumpered low pressure line switch
  • Jumpered high pressure line switch
  • Wiggled switch on compressor (could not get it to release, because I couldn't figure it out)
  • Clutch will turn by hand, engine running and not
  • Attempted to service low pressure port, but since the compressor was not running, the pressure at this port was 80+ PSI.
  • Checked AC clutch relay, AC Fuse, and AC diode
Because it ran so well just 12 hours ago, I feel like it something electrical.
Any ideas?
Thanks,
Jimmy
Old 06-18-2012, 02:10 PM
dad2bandm's Avatar
dad2bandm
dad2bandm is offline
Did you check the FAQ already...
I think this is likely your AC clutch gap, given what you described. Did you try tapping the clutch plate with the handle of screwdriver, to see if it engages then?
https://www.ford-trucks.com/forums/7...xpedition.html
Check this section:
"Symptom: No cooling. No engagement of compressor clutch"
Old 06-18-2012, 06:21 PM
pecanflyboy
Check this section:
As stated above my problem was the retaining bolt in the clutch. Thanks.
Old 06-18-2012, 09:40 PM
dad2bandm's Avatar
dad2bandm
Good to hear...I just had to adjust mine a little while back. Same issue.
Stay cool. :-)
Old 10-31-2012, 01:39 AM
NewShockerGuy's Avatar
NewShockerGuy
NewShockerGuy is offline
My ac completely just stopped working out of the blue as well.
What do you mean the ac bolt? I'm looking at the av and checked all relay, fuses..etc. The compressor isn't engaging at all...but I can turn it by hand it's not seized our anything like that....
Thanks
Nigel
Old 11-04-2012, 06:11 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Welcome to FTE, Nigel!
He was referring to the clutch gap. You adjust the gap by removing the center bolt in the clutch plate.
Checking and setting the clutch gap is outlined in the sticky at the top of the Forum.
Also, it's preferable to start a new thread about your issue instead of resurrecting an old thread. Just FYI.
Old 11-05-2012, 12:33 PM
NewShockerGuy
Thanks for the reply I will have to check out the sticky now!
Normally I'd start a new thread but figured searching is best so it doesn't clutter the board up with the same questions being asked over and over..
Thanks,
-Nigel
tractorboy924
07-13-2017 11:26 AM
backdraft341
01-11-2010 02:11 PM
michaelbrainardatwor
12-09-2007 08:01 AM
masseysbronco
1978 - 1996 Big Bronco
07-26-2005 02:22 PM
wardenj
08-11-2002 11:10 PM
Quick Reply: AC compressor will not come on.
