Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
2004 Explorer engine rattle
Old 06-10-2012, 08:50 PM
scooter3's Avatar
scooter3
scooter3 is offline
Question 2004 Explorer engine rattle
I own a 2004 Explorer Eddie Bauer Edition with 182,000 on the clock that has developed a very annoying engine rattle. The rattle started just shortly after having some service done on the truck. I had the P/S, Brake, Transmission and Rear diff fluids replaced. I also had the A/C system evacuated and recharged along with replacing the A/C manifold line and rack and pinion. The noise is most noticeable at first start and goes away when driving. I took it to Ford and they said that the timing belt tensioners were bad so they were replaced, but the noise was still there. Then they replaced the serpentine belt tensioner and pulley, but again noise is still there. I refused to have Ford do any more work since I had already been charged almost $1500 for repairs and the problem was not fixed. They said the next thing would be the balance shaft or rebuild the engine. The truck runs fine, smooth and does not shake at idle. It just has this awful noise. I have tried other forums with no luck so I am hoping someone can help me identify this issue; here is a video of the noise. Any help would be great.
http://youtu.be/jOijGtqUVQY[/URL]<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old 06-21-2012, 07:03 AM
scooter3's Avatar
scooter3
scooter3 is offline
200 views and not one comment?
Old 06-21-2012, 09:48 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Get your self a mechanics stethoscope or a length of rubber hose, then use it to isolate the source of the noise..
Keep in mind that crystal ball diagnosis is not recommended.... Philip
Old 06-24-2012, 12:37 PM
Eddie D's Avatar
Eddie D
Eddie D is offline
04 Rattle...
Hi,
Are you sure it is not a loose heat shield rattling underneath your truck. I have an 04 sport trac that rattled like crazy at idle, drove me crazy. so I went under my truck and ripped it of. No more rattling...
Anyway, just my two cents, hope it helps.
Ed
edford1
07-08-2013 06:13 PM
FoundOffRoadDominate
1999 to 2016 Super Duty
01-24-2012 08:35 PM
texag03
2004 - 2008 F150
13
05-11-2005 09:33 AM
94montana
13
08-16-2004 11:07 AM
pell
06-28-2004 09:01 PM
Quick Reply: 2004 Explorer engine rattle
