fuel pump/ relay
fuel pump/ relay
About a year ago I replaced the fuel pump on my wife's 03 4.6 EB expedition. I guess it gave out after 120xxx miles. It started up fine right after we installed it. Now, almost a year later, it has died again. We installed a Ford OEM pump, so I have my doubts that it went out for no reason. In addition, in the past couple of years, the car seems to randomly die for no reason. No warning, no signs, just dies. No codes either. Well, after doing some research, I saw a post about how someone else had a similar problem. They discovered the relay in the fuse box melted. I decided to investigate mine. After removing and disassembling the fuse box, I had a circuit board with five relays on it. I'm assuming that one of these is the R303 fuel pump relay. I'm cannot seem to figure out which one it is. There are five in a row and the middle one has what appears to be a burn bubble on the bottom side. Can someone tell me if this is the correct relay? Also, Would this have caused my new pump to short out? Thanks
Thomas
Thomas
OK, so tell me where is it? According to the owners manual, it is located in the fuse panel on the passenger-side kick panel. I am not aware of any other power distribution locations on this vehicle. It clearly states that the R303 "fuel pump relay" is located in the passenger-side fuse panel. It is also a non-serviceable relay as it is built in the circuit board.
How do you test the fuel pump outside of the tank? Can you put 12 volts directly to the pump and make it run?
