easy orphan fridge blinker fix
on
so the other day i noticed that the blinkers needed some work so we dug in and noticed the springs behind the buttons were wasted. went to the parts store and got the wrong replacement parts. back to the parts store for the right ones and began the resto.
then the clean-up and primer
some gloss white paint
cleaned up the brass sockets
after the cleanup the brass sockets were a little loose in the housing so we pressed them back in with a extra ground wire.back together and ready for the new insides and reinstallnapa part number is LS6469 and slides right into the stock socket location. wired back up and washed the inside of the blinker lenses. installed amber bulbs just for fun and away we go
on
just ran it up with the original wiring and used a self-tapping screw to mount it on the front part of the inner fender. looking back on it i could have just used the wire to tighten up the socket in the housing and then it would have grounded as it was designed. figure an extra ground cant hurt. its a wonder i never got pulled over. only had one front running light and one front blinker. on different sides. also had one low beam and one high beam out. now that its all fixed i will probably get pulled over. now i should be able to see what im about to hit................at night anyway!
Evan_P
62
04-12-2019 03:10 AM
PapaBearYuma
22
04-09-2017 04:50 PM
