My turn NO START I Found the Culprit
Old 06-05-2012, 08:31 PM
Supertommy68's Avatar
Supertommy68
Supertommy68 is offline
Last two weeks or so Mine was getting harder to start when hot. Taking longer and longer. Then at work last night was a no start. Lucky my boss was still there and gave me a 30-mile ride home. I had ICP up to 250, the best it would do in about 15 seconds. So this morning I brought 3.5 gallons of 15w-40 with me along with something to drain into. I tossed out the 5w-40 synthetic I was running, conveniently for the last two weeks, the same time frame for the hard- start. Now, with the heavier oil, it runs and starts fine even hot, at least today it did. Dang these things are tempermental!! Hopefully no permanent damage done.
Old 06-05-2012, 10:01 PM
BobbyB's Avatar
BobbyB
BobbyB is offline
Dang Benny, sorry to hear. I went through similar issues with mine a couple of times. I was taking out IPRs. When I did my oil cooler, I found that my HPOP screen had a tear. But I'm pretty sure you replaced yours last year. Good luck!
Old 06-05-2012, 10:20 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I was wrong with IPR being the culprit
Unpluged ICP Sensor and it Fired Right UP
ICP Defaulted to 1800 psi
Where is everyone Cheap ICP Sensors
Old 06-05-2012, 10:37 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
The SGII Just paid for itself again
Old 06-05-2012, 10:55 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
great, cheep and easy fix. Well not real easy on a 03, but easier than a HPOP
Piolet's Avatar
Piolet
Piolet is offline
Glads you got it sorted out Benny
I got my pigtail and sensor at my local International dealer.
$20.65 for the pigtail.
$98.85 for the sensor.
I also bought the Snap-on ICP specialty socket. I've used it a number of times and I like how it's worked for me.
http://image.snapon.com/international/pdf/S6196KR.pdf
Ian123's Avatar
Ian123
Ian123 is offline
Man I kinda wish I got a scan gauge now, I just realized my Edge Insight can't read IPR%
Anyways, glad you got it figured out!
Old 06-05-2012, 10:56 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Originally Posted by BLADE35
Did They find any metal shavings when you had a HPO Problem??? I saw 1 truck yesterday on here that they found metal shavings in it
These Early HPOP also Blow the BB Out the HPO Pump
I praying HPOP Good
I havent noticed any Drivabilty issues as of recent
Just a No-Start this AM
Nothing on the invoice about flushing the system, So if there was shavings they did not charge me for it.
Old 06-05-2012, 11:24 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Edge leaves you Hanging with some problems It dont have enough Gauges to diagnos some problems. The HPO system is one of them that the Edge falls short on and there are others
As far as Gauges go you cant Beat SGII
My SGII paid for itself Long time ago so this time it practically Paid for my ICP Sensor with money saved with a Diagnostic Fee at the shop I could even go a step Further and say it saved me a TOW Bill too
Old 06-05-2012, 11:33 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Thanks for posting that Info Have to rep ya down the road the Rep Gods have cut me off
Old 06-05-2012, 11:43 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
this from Tousley
Part Number 3C3Z9F838EA
Part Name SNS ASY-FU/INJ TIM P
MSRP $158.33
Core $0.00
Online Price $104.50
Going to try and find a International Dealer around me I have no idea where one is
Reped everyone I could I catch those I missed when it lets me
Thanks for the Help everyone
Old 06-06-2012, 07:33 AM
bowbender_1969's Avatar
bowbender_1969
bowbender_1969 is offline
Benny I haved an extra icp sensor laying around. It is used as I purchased a new one for my truck a couple months ago, but it was not the culprit so I believe this one to still be good. If you are interested I would let it go for a really good price.
  #28
Old 06-06-2012, 08:22 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Awesome! Cool you caught the default with the SG also. Good to know it works like that.
  #29
Old 06-06-2012, 12:15 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Just tried again no go
SGII=NO DTC
Innova 3120 code reader=NO DTC
KOEO Readings were
ICP=0
ICPV=0.09
IPR%=14.4
Cranking this time was
ICP=170-180
ICPV=0.36volt
IPR%=77.8%
FPW=0
Didnt unplug ICP Sensor yet
OEM Oil Filter and CAP
Oil Cooler work around 13K since
You now know as much as I do (Havent even Popped the Hood Yet) Hows Everyone betting on this what do you think Taking all Bets LOL
I am going to take a stab at it and say IPR
Huh??? Did I read right on the ICP volts reading obtained at Key-On/Engine-Off? On a 2003 the range you should be seeing is between 0.18 to 0.24 volts at Key-On/Engine-Off. That said, your reading is WAAAYYYYYY low. If I were you, I would slam dunk an ICP and pigtail at it, for a start before you go digging deeper.
EDIT: I didn't see that there was a page 2 to this thread. Flat Rate reading.
  #30
Old 06-06-2012, 01:31 PM
cay5628's Avatar
cay5628
cay5628 is offline
Does that snap on socket work on the 2007 model year 6.0 engine ICP? I may have to add that to my tool arsenal.
Quick Reply: My turn NO START I Found the Culprit
