1990 Ford 460 FI major power loss
Old 05-29-2012, 03:06 AM
vacuumbed's Avatar
vacuumbed
vacuumbed is offline
So true, it does look like a lego piece lol.
Old 08-04-2012, 01:48 PM
ciclone429's Avatar
ciclone429
ciclone429 is offline
pull spout?
what is the spout?
Old 08-04-2012, 01:51 PM
BRay09's Avatar
BRay09
BRay09 is offline
SPark OUTput. A piece that enables/disables computer advance. It needs to be removed to disable computer advance when setting base timing
Old 08-04-2012, 02:09 PM
ciclone429's Avatar
ciclone429
thank you. i will lok in manuel
Old 08-04-2012, 02:12 PM
w6pea's Avatar
w6pea
w6pea is offline
Originally Posted by ciclone429
what is the spout?
Where by chance is it located?
Old 08-04-2012, 02:41 PM
BRay09's Avatar
BRay09
BRay09 is offline
Depending on what year it could be near the distributor or over on the driver side fender
Old 08-16-2012, 08:54 PM
ciclone429's Avatar
ciclone429
power loss
removed the cat and other polution stuff. got the egr plug in module for the $20.00, replaced the fuel filter under driver feet and the recommended alternator belt (shorter due to pump removal). Truck runs great. thanks for the tips!
Old 08-16-2012, 09:14 PM
BRay09's Avatar
BRay09
BRay09 is offline
Did you do this all at once or see how the truck reacted after each? Curious to know what the actual problem was
Old 08-16-2012, 09:37 PM
ciclone429's Avatar
ciclone429
all at 1 time?
I cut cat off and drove and it was still bad. Did all the rest at one time and its fine
Old 08-19-2012, 01:05 AM
w6pea's Avatar
w6pea
w6pea is offline
Had the Cat replaced runs better but not much. I know a retired Ford Mechanic he's going to look at it tomorrow. He say's he doesn't beleive in the code readers, will test it with his voltmeter (he has all of his Ford Manuals from when he went to work until he retired) He has what is know as a treasure trove!
Old 08-19-2012, 08:28 AM
ciclone429's Avatar
ciclone429
cat
recycle the cat. i got 37.00 for mine at the place the buys alluminium
Old 08-20-2012, 08:39 AM
w6pea's Avatar
w6pea
w6pea is offline
I asked for the old Cat. The muffler shop said they had to send it in to have the haz-mat properly disposed of. This is California aka as Taxifornia.
  #28
Old 08-20-2012, 10:05 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Catalytic converters are not haz-mat - even in California. Platinum, Palladium and Rhodium are far, far too valuable to dispose of. Cat was scrapped and they kept the $60.
  #29
Old 08-20-2012, 12:19 PM
w6pea's Avatar
w6pea
w6pea is offline
Your probably right.
  #30
Old 08-23-2012, 06:36 PM
w6pea's Avatar
w6pea
w6pea is offline
Well according to my retired Mechanic Friend he say's it's the Ignition Control Module. I will have one tomorrow morning.
Quick Reply: 1990 Ford 460 FI major power loss
