97 4.2 F150 Coolant leaking into oil?
Old 05-23-2012, 04:17 PM
lilflippy's Avatar
lilflippy
lilflippy is offline
Hi Im trying to figure out why the antifreeze is leaking into the oil
Ok I ordered a new long block which came wth everthing new except had to transfer the Waterpump, timing cover, lower and upper intake manifold, oil pan from the old engine. Installed it and antifreeze was leaking into oil. So ripped out lower intake gasket replaced with another new one. Still antifreeze leaking into oil. Now did another check drained all oil out left oil plug out and just fill the coolant resevour up with coolant and without starting the engine up its antifreeze is pouring out the oil pan.what could be my problem?
Walking_boss
03-18-2018 12:03 AM
93f1505.0L
3.8 & 4.2L V6
01-10-2011 07:37 AM
anderson1549
3.8 & 4.2L V6
01-09-2011 09:37 AM
slomafarms
12-19-2008 05:44 AM
Quick Reply: 97 4.2 F150 Coolant leaking into oil?
